QOS on router Ethernet port
Answered Question
Nov 4th, 2011
My question is regarding assigning policy-maps to a interface.
Background:
The config I am posting is from a 2621 router. This routers Int fa0/0 connects to AT&Ts OPTEMAN 10Mbs Ethernet interface. The other end connects to our HQ router. At HQ is our PRIs and phone switches. I have configured QoS for this router, but don't I have to link them to the ingress interfacce (Int FA0/0)?
Here is the routers config:
sh run
Building configuration...
Current configuration : 1590 bytes
version 12.2
service password-encryption
hostname ACCESSRTR1
enable secret 5 $1$oKQI$9XtW3TrwSiaCB69qaw67T1
enable password 7 0505560A2F585C1048554653
ip subnet-zero
ip cef
no ip domain-lookup
call rsvp-sync
--More--                           !
class-map match-any Voice-Traffic
  match ip dscp ef
class-map match-any Voice-Signal
  match ip dscp cs3
  match ip dscp af31
class-map match-any Video
  match ip dscp af41
policy-map Voip
  class Voice-Traffic
    priority 20
  class Voice-Signal
   bandwidth percent 25
  class Video
  class class-default
policy-map OPTEMAN10M
  class class-default
   shape average 100000000 40000 0
--More--                              service-policy Voip
interface FastEthernet0/0
description OPTEMAN ERS Interface
ip address 10.10.10.2 255.255.255.248
duplex auto
speed 10
interface FastEthernet0/1
description Access LAN Interface
ip address 10.133.22.1 255.255.254.0
speed 100
full-duplex
router eigrp 1
network 10.0.0.0
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 10.133.1.0 255.255.255.0 10.10.10.1
--More--                           ip route 10.133.2.0 255.255.255.0 10.10.10.1
ip route 10.133.3.0 255.255.255.0 10.10.10.1
no ip http server
snmp-server community mccmh RO
snmp-server enable traps tty
dial-peer cor custom
line con 0
password 7 1107490019061915557A7A65
line aux 0
password 7 04555B0301355E5758495456
line vty 0
password 7 06085F24425A1B005447434A
login
line vty 1
password 7 130B4717051816337A747972
login
line vty 2 4
--More--                            password 7 130E1E1C0C4B50
login
end
ACCESSRTR1#
-Thanks for the help
in and out is relative to the router. In this case you want to apply the policy to the traffic going out of the router toward your HQ. On the HQ end you want another policy applied out toward your remote site. You don't need a policy inbound on either router because the bottleneck is not at the router ( it is the speed of your wan).
Correct Answer by Joseph W. Doherty about 5 years 9 months ago
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
service-policy Voip out (or it might be out Voip)
Correct Answer by cadet alain about 5 years 9 months ago
of course you have to apply this policy-map to an interface otherwise it will serve no purpose.
You must apply outbound on WAN interface as you are shaping. As Joseph remarked above shaping is done if you can send at a rate higher than the access rate or CIR and the ISP is policing traffic above that rate.
Is it the case for you?
setting the bandwidth of an interface  won't refrain it to send at the access rate.
Regards.
Alain
Overall Rating: 5 (3 ratings)
Joseph W. Doherty Fri, 11/04/2011 - 12:33
Disclaimer
Posting
If your WAN connection is only 10 Mbps and your LAN connection is 100 Mbps, you'll likely only need QoS on F0/0 egress.
PS:
If you get the full 10 Mbps on the WAN facing Ethernet there's no need to shape at 10 Mbps.
mccmhtac1 Fri, 11/04/2011 - 12:37
I will get full 10Mbs on the WAN facing Ethernet, that is why I set it's port speed to 10Mbs.
Do I need to apply andy of this to an interface:
  match ip dscp ef
  match ip dscp cs3
  match ip dscp af31
  match ip dscp af41
policy-map Voip
  class Voice-Traffic
    priority 20
  class Voice-Signal
  class Video
  class class-default
  class class-default
Correct Answer
cadet alain Fri, 11/04/2011 - 13:24
  • Purple, 4500 points or more
Regards.
Alain
mccmhtac1 Fri, 11/04/2011 - 16:45
Based on the config I provided, what commands will I use to correctly apply the policies?
Correct Answer
Joseph W. Doherty Fri, 11/04/2011 - 17:54
Disclaimer
Posting
mccmhtac1 Fri, 11/04/2011 - 18:17
pardon me for not understanding. but wouldn't that policy be 'in' not 'out'?
Joseph W. Doherty Sat, 11/05/2011 - 04:30
Disclaimer
Posting
If f0/0 is the MPLS connection, out is correct.
cadet alain Sat, 11/05/2011 - 09:33
you can't apply a QoS policy with shaping or CBWFQ config inbound, it must be outbound and in your case on the interface towards MPLS.
Alain
Correct Answer
Related Content
