Cisco Presence 8.5 CSF client on terminal services
Nov 5th, 2011
Hello
I need to install the cisco presence client in a terminal services environment.
I am pretty sure you can but I need to locate the installation guide for that and also need to understand the limitations of the client in terminal services mode.
I am thinking that audio and softphone would have issues.
thanks
Christos Georgiadis Sun, 11/06/2011 - 14:47
  • Silver, 250 points or more
Hi Bill,
You are correct. Check out the release notes
http://www.cisco.com/en/US/docs/voice_ip_comm/cupc/8_5/english/release/notes/cupc85.html#wp274793
Virtual Desktop Infrastructure (VDI) Support
Cisco Unified Personal Communicator Release 8.5(4) is supported on the following hosted virtual desktop applications:
•VMware View 4.5
•Citrix XenDesktop 4.0
Note In a virtualized desktop environment, full audio and video capabilities are only available on Cisco Unified Personal Communicator when you are using the desk phone for phone calls. If you are using the phone on your computer, only the voicemail features are supported in a virtualized environment.
HTH,
Christos
BILL PETERSEN Sun, 11/06/2011 - 19:59
Hi christos
The customer is using plain old windows terminal server for their thin clients
Any thoughts on that?
Bill
Connected by DROID on Verizon Wireless
Christos Georgiadis Mon, 11/07/2011 - 08:19
Hey Bill
Then I would say that this is not a supported scenario.
But in any case I would think that the deskphone control and chat should work fine.
I cannot say the same for the softphone mode though,
HTH,
Christos
sanotto Wed, 05/16/2012 - 05:04
Bill,
Any feedback on the CSF functioning on terminal services?, did the chat, presence and phone control have issues?
Appreciate your comments,
Otto
Yue bun Yuen Mon, 06/04/2012 - 09:00
Yes, I also want to know any limitation for runing the CSF under thin client.
Jaime Valencia Tue, 06/05/2012 - 17:57
  • Cisco Employee,
  • Hall of Fame,
    2011
Supported virtual  functionality
Cisco  Jabber for Windows in a virtual environment supports the  following functionality:
  • Instant  messaging and presence
  • Desk  phone control
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_01000.html#reference_B1477134C1A14086B4C9B7BD3A2EAE7D
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
