11-06-2011 05:25 AM
We purchased a SRP527W for test purposes.
The product cannot detect ADSL line.
CD light is off.
The line works fine with an 877 router, so we assume that this is not a line problem.
Any help will be appreciated.
Firmware version 1.1.24
11-06-2011 06:37 AM
Under Status -->Status ADSL --> Status ADSL
DSL Status: G.994 Training
DSL Modulaion Mode: NOT TRAINED
Does that mean that the ADSL interface is unavailable to detect DSL connection from provider?
Is it a defect interface port?
I downgraded the firmware version to 1.1.23 and I was able to get connected to my ISP.
Unfortunately the router can' t get an IP address (WAN Interface).
Any Help?
Message was edited by: Dimitris Mingos
11-07-2011 03:00 AM
Have you checked to make sure that the DSL Interface is Enabled on the device? Check under the Administration Tab
and then under Switch Setting.
THANKS
Rick Roe
Cisco Small Business SUpport Center
11-07-2011 03:53 AM
Please also check the line modulation setting for the ADSL interface.
Normally, this should be set for multimode, which automatically detects the line type. You might need to set this manually though to meet your specific needs.
Andy
11-07-2011 06:15 AM
Thank you for your response.
We use a 877 router, is working perfect with the line.
We used correct setting for the DSL interface.
ADSL2+,
8/35,
and the interface is enabled.
Maybe a hardware failure.
Dimitris
11-07-2011 06:25 AM
It's always a possibility.
Could you log in to the SRP500 GUI, then change the URL in the address bar to read:
http://192.168.15.1/dsldiag.asp
This will show a "hidden" status page that might offer more clues.
Andy
