LMS - Alerting
Answered Question
Nov 6th, 2011
Can LMS monitor 3rd party servers? Customer want LMS to send an e-mail alert when server IP address is unreachable.
Is this possible?
C
Correct Answer by Ferenc Kuris about 5 years 3 months ago
I would set up an IP SLA. But if you monitor the interface, you monitor the server, too  or is it a virtual server?
Br,
Frank
You should monitore that interface to what the server is attached, and monitor it's status. You can do it here: Monitor -> Fault settings -> Setup -> Fault device details. Click onthe switch, view, click on it's name, and set the interface to true.
Overall Rating: 5 (2 ratings)
Correct Answer
Ferenc Kuris Mon, 11/07/2011 - 00:42
colmgrier Mon, 11/07/2011 - 01:13
Thanks Ferenc.
Any way to monitor the IP address of the server?
regards,
C
Correct Answer
Ferenc Kuris Mon, 11/07/2011 - 11:44
Br,
Frank
