Warning message
Need help for Australia E1
Answered Question
Nov 6th, 2011
To make a long story short, my organization (99.9 percent US) is standing up an office in Canberra, Australia. We ordered an E1 from Telstra but have had problems getting it stood up. Coming from the wall is a Telstra modem of some kind, labeled NTU-WS. It has a G.703 light on it that is blinkin red and green.
The gateway we have is a 3925 with a VWIC3-1MFT-T1/E1 module. We are concerned there is some aspect of the Telstra E1 deployment we missed. What do we need to do to get this working?
Can anyone give a poor US guy some pointers on AUS E1's?
Correct Answer by mcreilly about 5 years 9 months ago
This is a cut and paste from one of my routers in Australia that's working fine with a Telstra E1...
card type e1 0 0
isdn switch-type primary-net5
isdn voice-call-failure 0
controller E1 0/0/0
pri-group timeslots 1-31
description ISDN30 +61 x xxxx xxxx
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn overlap-receiving
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
cptone AU
bearer-cap Speech
How far do you get? E.g. can you see the controller as UP but the voice ports down, or not even get that far? The only thing I remember finding to be different in Aus to most other countries was having to use "isdn overlap-receiving" to get the incoming caller ID to work right (but then it's a couple of years since I installed IPT in those offices).
Correct Answer by Marwan ALshawi about 5 years 9 months ago
nothing just standard config of an E1
below copy of cofing used with telestra using cisco VGW 29xx
card type e1 0 x
network-clock-participate wic x
network-clock-select 1 E1 0/x/0
voice-port 0/x/0:15
cptone AU
controller E1 0/x/0
pri-group timeslots 1-xx   ---- where xx number of channel you have
if you are using MGCP:
controller E1 0/2/0
pri-group timeslots 1-20 service mgcp
if you have translation for incominfg calls DID, Telestra sometimes the do not send the leading 0 for example if the DID 02yXXXXX
they might send it either 2yXXXXX or yXXXXXXXX
hope this help
if helpful Rate
Overall Rating: 5 (2 ratings)
Correct Answer
Marwan ALshawi Sun, 11/06/2011 - 18:39
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
card type e1 0 x
voice-port 0/x/0:15
cptone AU
controller E1 0/x/0
controller E1 0/2/0
hope this help
if helpful Rate
Correct Answer
mcreilly Mon, 11/07/2011 - 01:58
card type e1 0 0
controller E1 0/0/0
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
cptone AU
bearer-cap Speech
