Warning message
OSPF DR and BDR bidding question
Nov 7th, 2011
hi:
i am using Packet tracer to test OSPF DR and BDR bidding.
according to text book, if the interface's router ID is the highest , it will become DR and the next highest will be BDR.
but in my test, i don't see this happening .
R1's conf
interface Loopback101
ip address 100.100.100.100 255.255.255.0
interface FastEthernet0/0
ip address 1.1.1.10 255.0.0.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 1
ip classless
line con 0
line vty 0 4
login
end
R1's "show ip protocols"
Routing Protocol is "ospf 1"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Router ID 100.100.100.100
  Number of areas in this router is 1. 1 normal 0 stub 0 nssa
  Maximum path: 4
  Routing for Networks:
  Routing Information Sources:
    Gateway         Distance      Last Update
    1.1.1.1              110      00:00:43
  Distance: (default is 110)
R2's conf
hostname R2
interface Loopback1
ip address 10.10.10.10 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
ip address 1.1.1.1 255.0.0.0
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router ospf 1
ip classless
line con 0
line vty 0 4
login
end
R2's IP protocol details
  Router ID 10.10.10.10
  Maximum path: 4
    1.1.1.10             110      00:01:51
obviously R1 has higher router ID.
but at the end
R1#show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.10.10.10       1   FULL/BDR        00:00:35    1.1.1.1         FastEthernet0
R2#show ip ospf neighbor
100.100.100.100   1   FULL/DR         00:00:35    1.1.1.10        FastEthernet1/0
as it shows from above data, R2 was chosen as DR despite that R1 has higher Router ID and they both have same priority number.
please help me out on this, i have been thinking for hours.
Peter Paluch Mon, 11/07/2011 - 10:41
  • Cisco Employee,
I believe you are simply reading the output incorrectly. R1 is the DR and R2 is the BDR. The output says:
R1 knows about a neighbor whose RID is 10.10.10.10, IP address is 1.1.1.1 and whose state is BDR.
R2 knows about a neighbor whose RID is 100.100.100.100, IP address is 1.1.1.10 and whose state is DR.
The show ip ospf neighbor shows your neighbor's roles, not your own.
Best regards,
Peter
Related Content
