DHCP snooping clients not getting IP address
manishdshah28
I have got two access switches where almost 50 PCs connected. I have enabled DHCP snooping on those switches.
Once I enabled DHCP snooping on those switches existing clients works fine but If I plug a new device it is unable to get an IP Address assigned.
I have enabled IP DHCP snooping, IP DHCP snooping vlan 3 (Data VLAN) where clients and DHCP server resides.
I have also enabled DHCP snoop trust option on the trunk interfaces and DHCP snoop with rate limit of 3 is applied on all client intefaces.
The DHCP server resides on VLAN 3 (same as the clients) but on the other switch where I haven't enabled DHCP snooping yet.
While I try to debug, I get following messgaes on switch... (client trying to get Ip has the mac address sa: 0024.e8b4.ec05 )
018764: Nov 8 05:03:18.000 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0024.e8b4.ec05, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0024.e8b4.ec05
018765: Nov 8 05:03:18.000 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
018766: Nov 8 05:03:18.000 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
018767: Nov 8 05:03:22.522 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018768: Nov 8 05:03:22.522 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/2
018769: Nov 8 05:03:22.522 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018770: Nov 8 05:03:22.522 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
018771: Nov 8 05:03:22.522 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018772: Nov 8 05:03:22.522 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/2
018773: Nov 8 05:03:22.522 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018774: Nov 8 05:03:22.522 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
018775: Nov 8 05:03:22.522 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0024.e8b4.ec05, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0024.e8b4.ec05
018776: Nov 8 05:03:22.522 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
018777: Nov 8 05:03:22.522 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
018778: Nov 8 05:03:29.417 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018779: Nov 8 05:03:29.417 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/2
018780: Nov 8 05:03:29.417 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018781: Nov 8 05:03:29.417 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
018782: Nov 8 05:03:29.417 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018783: Nov 8 05:03:29.417 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/2
018784: Nov 8 05:03:29.417 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018785: Nov 8 05:03:29.417 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
018786: Nov 8 05:03:29.417 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0024.e8b4.ec05, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0024.e8b4.ec05
018787: Nov 8 05:03:29.417 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
018788: Nov 8 05:03:29.417 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
018789: Nov 8 05:03:31.934 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018790: Nov 8 05:03:31.934 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/2
018791: Nov 8 05:03:31.934 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak. Was not set
018792: Nov 8 05:03:31.934 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
Any clue.. why is this happening
cadet alain
Have you configured this on the switch:  no ip dhcp snooping information option   ?
if not then do it and tell us if it solves the problem.
Regards.
Alain.
16 Replies 16
cadet alain
Regards.
Alain.
Hi Cadet,
It resolved the issue straight away, thanks.
Sorry Alain, I got you wrongly mentioned in my reply.
Hi Alain,
I think I declared the victory too soon, I have got another two people this morning comming back from their holidays face the issue getting IP adress again when dhcp snooping was enabled, existing users are all fine.
Any further debugging you suggest?
Mnaish.
if on clients already in the binding state you do a ipconfig/release then ipconfig/renew, are they also not getting an ip address?
Also provide output of sh ip dhcp snooping
Regards.
Alain
No, the client is not in binding state, as I mentioned in my initial question, only people come back after their holidays are facing this issue. I have disabled dhcp snooping as users were unable to get IP address.
But this is what I saw on dhcp snoop debug for that perticular clinet...(when he was trying to acquire IP address)
040746: Nov  9 01:06:31.701 UTC: %LINK-3-UPDOWN: Interface FastEthernet0/23, changed state to up
040747: Nov  9 01:06:32.707 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to up
040748: Nov  9 01:06:33.270 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/23 for pak.  Was not set
040749: Nov  9 01:06:33.270 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/23
040750: Nov  9 01:06:33.270 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/23 for pak.  Was not set
040751: Nov  9 01:06:33.270 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/23)
040752: Nov  9 01:06:33.270 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/23, MAC da: ffff.ffff.ffff, MAC sa: 0021.70eb.fc90, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0021.70eb.fc90
040753: Nov  9 01:06:33.270 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
040754: Nov  9 01:06:33.270 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
040755: Nov  9 01:06:33.270 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
040756: Nov  9 01:06:33.270 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
040757: Nov  9 01:06:33.270 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
040758: Nov  9 01:06:33.278 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
040759: Nov  9 01:06:34.738 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
040760: Nov  9 01:06:34.738 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
040761: Nov  9 01:06:34.738 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
Manish.
yes it was the initial debug you provided but if you have clients working ok, what if you release and renew the ip address is it the same result and debug?
Can you also provide  sh ip dhcp snooping output as requested
Regards.
Alain
ok, what I did is have a client connected when dhcp snooping was not enabled, the client got IP address. Then I enabled dhcp snooping and did release renew and client didn't get ip address.
so here is the output...
I have got a client just got ip address and then dhcp snooping just enabled on the switch and then took the output of the commands you have asked..
show ip dhcp snooping bind
MacAddress          IpAddress        Lease(sec)  Type           VLAN  Interface
00:13:72:95:83:B4   10.3.13.57       431970      dhcp-snooping   3     FastEthernet0/22
Total number of bindings: 1
#show ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
   circuit-id default format: vlan-mod-port
   remote-id: 0019.e7a3.ba80 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
FastEthernet0/1            no         no              3
  Custom circuit-ids:
FastEthernet0/2            no         no              3
  Custom circuit-ids:
FastEthernet0/3            no         no              3
  Custom circuit-ids:
FastEthernet0/4            no         no              3
  Custom circuit-ids:
FastEthernet0/5            no         no              3
  Custom circuit-ids:
FastEthernet0/6            no         no              3
  Custom circuit-ids:
FastEthernet0/7            no         no              3
  Custom circuit-ids:
FastEthernet0/8            no         no              3
  Custom circuit-ids:
FastEthernet0/9            no         no              3
  Custom circuit-ids:
FastEthernet0/10           no         no              3
  Custom circuit-ids:
FastEthernet0/11           no         no              3
  Custom circuit-ids:
FastEthernet0/12           no         no              3
  Custom circuit-ids:
FastEthernet0/13           no         no              3
  Custom circuit-ids:
FastEthernet0/14           no         no              3
  Custom circuit-ids:
FastEthernet0/15           no         no              3
  Custom circuit-ids:
FastEthernet0/16           no         no              3
  Custom circuit-ids:
FastEthernet0/17           no         no              3
  Custom circuit-ids:
FastEthernet0/18           no         no              3
  Custom circuit-ids:
FastEthernet0/19           no         no              3
  Custom circuit-ids:
FastEthernet0/20           no         no              3
  Custom circuit-ids:
FastEthernet0/21           no         no              3
  Custom circuit-ids:
FastEthernet0/22           no         no              3
  Custom circuit-ids:
FastEthernet0/23           no         no              3
  Custom circuit-ids:
FastEthernet0/25           no         no              3
  Custom circuit-ids:
FastEthernet0/26           no         no              3
  Custom circuit-ids:
FastEthernet0/27           no         no              3
  Custom circuit-ids:
FastEthernet0/28           no         no              3
  Custom circuit-ids:
FastEthernet0/29           no         no              3
  Custom circuit-ids:
FastEthernet0/30           no         no              3
  Custom circuit-ids:
FastEthernet0/31           no         no              3
  Custom circuit-ids:
FastEthernet0/32           no         no              3
  Custom circuit-ids:
FastEthernet0/33           no         no              3
  Custom circuit-ids:
FastEthernet0/34           no         no              3
  Custom circuit-ids:
FastEthernet0/35           no         no              3
  Custom circuit-ids:
FastEthernet0/36           no         no              3
  Custom circuit-ids:
FastEthernet0/37           no         no              3
  Custom circuit-ids:
FastEthernet0/38           no         no              3
  Custom circuit-ids:
FastEthernet0/39           no         no              3
  Custom circuit-ids:
FastEthernet0/40           no         no              3
  Custom circuit-ids:
FastEthernet0/41           no         no              3
  Custom circuit-ids:
FastEthernet0/42           no         no              3
  Custom circuit-ids:
FastEthernet0/43           no         no              3
  Custom circuit-ids:
FastEthernet0/44           no         no              3
  Custom circuit-ids:
FastEthernet0/45           no         no              3
  Custom circuit-ids:
FastEthernet0/46           no         no              3
  Custom circuit-ids:
FastEthernet0/47           no         no              3
  Custom circuit-ids:
FastEthernet0/48           no         no              3
  Custom circuit-ids:
GigabitEthernet0/1         yes        yes             unlimited
  Custom circuit-ids:
GigabitEthernet0/2         yes        yes             unlimited
  Custom circuit-ids:
Now I did release and renew on client and the output of the debug is as under..The client I am talking about is connected on the switch port Fa0/22.
41778: Nov  9 09:41:35.214 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041779: Nov  9 09:41:35.214 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041780: Nov  9 09:41:35.214 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041781: Nov  9 09:41:35.214 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041782: Nov  9 09:41:35.214 UTC: DHCP_SNOOPING: process new DHCP packet, message type: BOOTPMSG, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0002.4b83.9f40, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0002.4b83.9f40
041783: Nov  9 09:41:35.214 UTC: DHCP_SNOOPING: bridge a BOOTP packet or an unknown msg type dhcp packet, op code = 1
041784: Nov  9 09:41:35.214 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041785: Nov  9 09:41:51.849 UTC: DHCP_SNOOPING: checking expired snoop binding entries
041786: Nov  9 09:42:09.004 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041787: Nov  9 09:42:09.004 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041788: Nov  9 09:42:09.004 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041789: Nov  9 09:42:09.004 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041790: Nov  9 09:42:09.004 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPRELEASE, input interface: Fa0/22, MAC da: 101f.743b.2ed4, MAC sa: 0013.7295.83b4, IP da: 10.3.12.59, IP sa: 10.3.13.57, DHCP ciaddr: 10.3.13.57, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041791: Nov  9 09:42:09.004 UTC: DHCP_SNOOPING: delete binding from port FastEthernet0/22.
041792: Nov  9 09:42:09.012 UTC: DHCP_SNOOPING: dump binding entry: Mac=00:13:72:95:83:B4 Ip=10.3.13.57 Lease=431864     Type=dhcp-snooping Vlan=3 If=FastEthernet0/22
041793: Nov  9 09:42:09.012 UTC: DHCP_SNOOPING_SW no entry found for 0013.7295.83b4 0.0.0.3 FastEthernet0/22
041794: Nov  9 09:42:09.012 UTC: DHCP_SNOOPING_SW host tracking not found for update remove dynamic (10.3.13.57, 0.0.0.0, 0013.7295.83b4) vlan 3
041795: Nov  9 09:42:09.012 UTC: DHCP_SNOOPING_SW: bridge packet send packet to port: GigabitEthernet0/2, vlan 3.
041796: Nov  9 09:42:12.225 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041797: Nov  9 09:42:12.225 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041798: Nov  9 09:42:12.225 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041799: Nov  9 09:42:12.225 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041800: Nov  9 09:42:12.225 UTC: DHCP_SNOOPING: process new DHCP packet, message type: BOOTPMSG, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0002.4b83.9f40, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0002.4b83.9f40
041801: Nov  9 09:42:12.233 UTC: DHCP_SNOOPING: bridge a BOOTP packet or an unknown msg type dhcp packet, op code = 1
041802: Nov  9 09:42:12.233 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041803: Nov  9 09:42:18.550 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041804: Nov  9 09:42:18.550 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041805: Nov  9 09:42:18.550 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041806: Nov  9 09:42:18.550 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041807: Nov  9 09:42:18.550 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041808: Nov  9 09:42:18.550 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041809: Nov  9 09:42:19.397 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041810: Nov  9 09:42:19.397 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041811: Nov  9 09:42:19.397 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041812: Nov  9 09:42:19.397 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041813: Nov  9 09:42:19.397 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
041814: Nov  9 09:42:21.545 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041815: Nov  9 09:42:21.545 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041816: Nov  9 09:42:21.545 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041817: Nov  9 09:42:21.545 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041818: Nov  9 09:42:21.545 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041819: Nov  9 09:42:21.545 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041820: Nov  9 09:42:21.545 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041821: Nov  9 09:42:21.545 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041822: Nov  9 09:42:21.545 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041823: Nov  9 09:42:21.545 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041824: Nov  9 09:42:21.545 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
041825: Nov  9 09:42:29.539 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041826: Nov  9 09:42:29.539 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041827: Nov  9 09:42:29.539 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041828: Nov  9 09:42:29.539 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041829: Nov  9 09:42:29.539 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041830: Nov  9 09:42:29.539 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041831: Nov  9 09:42:29.547 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041832: Nov  9 09:42:29.547 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041833: Nov  9 09:42:29.547 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041834: Nov  9 09:42:29.547 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041835: Nov  9 09:42:29.547 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
041836: Nov  9 09:42:44.538 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041837: Nov  9 09:42:44.538 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041838: Nov  9 09:42:44.538 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041839: Nov  9 09:42:44.538 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041840: Nov  9 09:42:44.538 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041841: Nov  9 09:42:44.538 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041842: Nov  9 09:42:44.546 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041843: Nov  9 09:42:44.546 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041844: Nov  9 09:42:44.546 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041845: Nov  9 09:42:44.546 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041846: Nov  9 09:42:44.546 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
041847: Nov  9 09:42:49.244 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041848: Nov  9 09:42:49.244 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041849: Nov  9 09:42:49.244 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041850: Nov  9 09:42:49.244 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041851: Nov  9 09:42:49.244 UTC: DHCP_SNOOPING: process new DHCP packet, message type: BOOTPMSG, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0002.4b83.9f40, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0002.4b83.9f40
041852: Nov  9 09:42:49.244 UTC: DHCP_SNOOPING: bridge a BOOTP packet or an unknown msg type dhcp packet, op code = 1
041853: Nov  9 09:42:49.244 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041854: Nov  9 09:43:02.750 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041855: Nov  9 09:43:02.750 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041856: Nov  9 09:43:02.750 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041857: Nov  9 09:43:02.750 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041858: Nov  9 09:43:02.750 UTC: DHCP_SNOOPING_SW: client address lookup failed to locate client interface, retry lookup using packet mac DA: ffff.ffff.ffff
041859: Nov  9 09:43:02.750 UTC: DHCP_SNOOPING_SW: lookup packet destination port failed to get mat entry for mac: 0013.7295.151f
041860: Nov  9 09:43:02.750 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPINFORM, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.151f, IP da: 255.255.255.255, IP sa: 10.3.13.13, DHCP ciaddr: 10.3.13.13, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.151f
041861: Nov  9 09:43:02.750 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041862: Nov  9 09:43:21.951 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041863: Nov  9 09:43:21.951 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041864: Nov  9 09:43:21.951 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041865: Nov  9 09:43:21.951 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041866: Nov  9 09:43:21.951 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041867: Nov  9 09:43:21.951 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041868: Nov  9 09:43:21.951 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041869: Nov  9 09:43:21.951 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041870: Nov  9 09:43:21.951 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041871: Nov  9 09:43:21.951 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041872: Nov  9 09:43:21.951 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
041873: Nov  9 09:43:25.944 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041874: Nov  9 09:43:25.944 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041875: Nov  9 09:43:25.944 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041876: Nov  9 09:43:25.944 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041877: Nov  9 09:43:25.944 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041878: Nov  9 09:43:25.952 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041879: Nov  9 09:43:25.952 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041880: Nov  9 09:43:25.952 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041881: Nov  9 09:43:25.952 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041882: Nov  9 09:43:25.952 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041883: Nov  9 09:43:25.952 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse
041884: Nov  9 09:43:26.238 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041885: Nov  9 09:43:26.238 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041886: Nov  9 09:43:26.238 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041887: Nov  9 09:43:26.238 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041888: Nov  9 09:43:26.238 UTC: DHCP_SNOOPING: process new DHCP packet, message type: BOOTPMSG, input interface: Gi0/2, MAC da: ffff.ffff.ffff, MAC sa: 0002.4b83.9f40, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0002.4b83.9f40
041889: Nov  9 09:43:26.238 UTC: DHCP_SNOOPING: bridge a BOOTP packet or an unknown msg type dhcp packet, op code = 1
041890: Nov  9 09:43:26.246 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041891: Nov  9 09:43:34.945 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041892: Nov  9 09:43:34.945 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Fa0/22
041893: Nov  9 09:43:34.945 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/22 for pak.  Was not set
041894: Nov  9 09:43:34.945 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/22)
041895: Nov  9 09:43:34.945 UTC: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/22, MAC da: ffff.ffff.ffff, MAC sa: 0013.7295.83b4, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0013.7295.83b4
041896: Nov  9 09:43:34.945 UTC: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (3)
041897: Nov  9 09:43:34.953 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041898: Nov  9 09:43:34.953 UTC: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak.  Was Gi0/2
041899: Nov  9 09:43:34.953 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
041900: Nov  9 09:43:34.953 UTC: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/2)
041901: Nov  9 09:43:34.953 UTC: DHCP_SNOOPING: invalid DHCP options - unable to parse 41778: Nov  9 09:41:35.214 UTC: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/2 for pak.  Was not set
you are  receiving packets on the the link going to the server but it is ignored by the switch for some reasons
Can you debug ip dhcp server packets on the DHCP server and mirror traffic ingress on this trunk and save as pcap and post  both of them here.
Regards.
Alain
Hi Alain, I have go Window Server being used as DHCP server so I guess I would not be able to run "debug ip dhcp server packets"
I also thought it is worthwhile mentioning few more info. that might help...
We use additional bit of information in DHCP scope as under as we use Cisco Wireless Controller in our lan and we want Wireless controller boot from it..
I am letting you know as I wonder if that is what is adding complexicity?  (please find extract of DHCP scope options)
                    043      Vendor Specific Info
                    241                   Option 43            Cisco 1240 Series AP
If Windows server then effectively disabling option 82 was surely not the solution to the problem.
I'll take a look and think it over maybe it is the problem but I can't tell for sure.
Can you mirror the traffic ingress/egress on the link to DHCP server and post the pcap file
Regards.
Alain
Hi, I have this problem too , I have Insertion of option 82 is disabled but users still can't get ip .
ho ip dhcp snoo
Switch DHCP snooping is disabled
   remote-id: 3cce.733c.b380 (MAC)
GigabitEthernet1/0/26      yes        yes             unlimited
WS-C2960S-24TS-L,  Version 12.2(55r)SE,
Hi Bekzod,
Perhaps it would be better for you to open a new thread - this one is years old, extending it with new discussion will just decrease its overall readability, and your issue may be different.
One comment, though: According to your show ip dhcp snooping command output, your switch does not even run DHCP Snooping (see the line above saying that the switch DHCP snooping is disabled). So if, in this configuration, your clients are not getting any DHCP assignments then the issue is most probably elsewhere.
Best regards,
Peter
no im sorry, i have disabled dhcp snooping because of this issue this is working office they need internet
