Warning message
destination nat - vpn site2site
Nov 8th, 2011
Good day all,
hope someone can help/explain me destination nat.
I have one host A 172.20.0.x that must translate to host B 192.168.5.x.
So if a vpn office (192.168.36.0/24) try to connect to host A 172.20.0.x it must translate to host B 192.168.5.x.
Is this possible and how I can configure this NAT rule.
I using ASA V8.4(1)
Many thanks for your feedback!
Brgds Markus
zulqurnain Tue, 11/08/2011 - 02:22
  • Bronze, 100 points or more
What I understood is that your host 172.20.0.x is sitting on inside network and you want this host to be available on outside network /published as 192.168.5.x , such that other host connecting to it would be connecting to 192.168.5.x and ASA will do the translation .
You can achieve it as following
Static (inside, outside) 192.168.15.x 172.20.0.x net mask 255.255.255.255
Access-list out-in extended permit ip 192.168.36.0 255.255.255.0 host 192.168.5.x
Access-group out-in in interface outside
Markus Demmert Tue, 11/08/2011 - 06:06
thanks for the fast response.
The Host B 192.168.5.X is also on an inside interface. I will that all remote VPN locations that try to connect to host A 172.0.0.X translated to host B 192.168.5.X.
Brgds Markus
zulqurnain Tue, 11/08/2011 - 07:26
I am sorry but can you explain , if you have 192.168.5.x and 172.0.0.x are on inside network meaning both hosts are live then in such a case both would be used by VPN users simultaneously., correct ?
Then you cannot translate host A to host B address because translation can happen using VIP (virtual IP) with real IP.
What you are talking about it diversion or maybe I mis understood you and if you can explain more I might be able to help you out.
Markus Demmert Tue, 11/08/2011 - 07:26
Ok I got it,
nat (wan_primary,inside) source static 192.168.36.0 192.168.36.0 destination static 172.20.0.X 192.168.5.X
Brgds Markus
