Warning message
QoS Bandwidth Calculation Question
Nov 8th, 2011
I'm trying to write a QoS policy for a branch router using CBWFQ to utilize the priority queue for voice.  I already know how much bandwidth I need for each traffic class.  So I am trying to calculate the percentage of BW required based on how much BW I need. I am having trouble with the percentage of traffic I am reserving matching up with the actual amount of BW I am trying to reserve.
From what I have read, when using the remaining bandwidth command, the percentage of bandwidth is calculated by the following logic:  remaining BW = interface total BW - (priority queue + .25 * interface BW).  The percentage allocated using the remaining bandwidth command is calculated using the remaining BW not the interface total BW.
If the above is true, then why aren't my numbers matching up with the BW in the show policy-map command?  I have configured an Ethernet interface for 1536 BW.
1536 * .25 = 384 (25% non-reservable)
1536 * .21 = 322.56 (21% for priority queue)
384 + 322.56 = 706.56 (25% of int BW + 21% for priority queue)
1536 - 706.56 = 829.44 (remaining available BW)
I know I want to allocate 77kbps for voice signaling, which is 9% of the remaining BW.  77 / 829.44 = .0928.  However, the show policy-map interface command shows a different amount of BW reserved for 9%.  It shows 109 kbps.  I believe it gets 109 kpbs by calculating the remaining BW from the interface BW - priority queue, not interface bandwidth -(non-reservable BW + priority queue BW).
Does anyone know why I am seeing this?
----------LAB Configuration----------
class-map match-any VOICE-TRAFFIC
match access-group name VOICE-TRAFFIC
class-map match-all DEFAULT
match access-group name DEFAULT
class-map match-any MISSION-CRITICAL-APPS
match access-group name MISSION-CRITICAL-APPS
class-map match-any NETWORK-MANAGEMENT
match access-group name NETWORK-MANAGEMENT
class-map match-any IP-ROUTING
match access-group name IP-ROUTING
class-map match-any CALL-SIGNALING
match access-group name CALL-SIGNALING
policy-map STORES-QOS-POLICY
description DSW Store Router QoS Policy
class CALL-SIGNALING
  set dscp cs3
    bandwidth remaining percent 9
class IP-ROUTING
  set dscp cs6
    bandwidth remaining percent 15
class MISSION-CRITICAL-APPS
  set dscp af31
    bandwidth remaining percent 28
class NETWORK-MANAGEMENT
  set dscp cs2
class DEFAULT
  set dscp default
class VOICE-TRAFFIC
  set dscp ef
    priority percent 21
interface FastEthernet0/1
bandwidth 1536
no ip address
shutdown
duplex auto
speed auto
service-policy output STORES-QOS-POLICY
yourname#show policy-map int fa0/1
FastEthernet0/1
  Service-policy output: STORES-QOS-POLICY
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: CALL-SIGNALING (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name CALL-SIGNALING
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      QoS Set
        dscp cs3
          Packets marked 0
      bandwidth remaining 9% (109 kbps)
    Class-map: IP-ROUTING (match-any)
      0 packets, 0 bytes
      Match: access-group name IP-ROUTING
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      QoS Set
        dscp cs6
          Packets marked 0
      bandwidth remaining 15% (182 kbps)
    Class-map: MISSION-CRITICAL-APPS (match-any)
      0 packets, 0 bytes
      Match: access-group name MISSION-CRITICAL-APPS
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      QoS Set
        dscp af31
          Packets marked 0
      bandwidth remaining 28% (339 kbps)
    Class-map: NETWORK-MANAGEMENT (match-any)
      0 packets, 0 bytes
      Match: access-group name NETWORK-MANAGEMENT
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      QoS Set
        dscp cs2
          Packets marked 0
    Class-map: DEFAULT (match-all)
      0 packets, 0 bytes
      Match: access-group name DEFAULT
      QoS Set
        dscp default
          Packets marked 0
    Class-map: VOICE-TRAFFIC (match-any)
      0 packets, 0 bytes
      Match: access-group name VOICE-TRAFFIC
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        dscp ef
          Packets marked 0
      Priority: 21% (322 kbps), burst bytes 8050, b/w exceed drops: 0
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
Joseph W. Doherty Tue, 11/08/2011 - 10:46
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
"1536 * .25 = 384 (25% non-reservable)"
a) that can be changed on the interface - has it been?
b) 25% default was changed in later IOS versions, what IOS version are you running?
Your remaining percent number all appear to be BW - priority %.
jzangmeister Tue, 11/08/2011 - 11:35
Answers to your questions:
a) I have not changed the max-reserved-bandwidth on the interface.
b) IOS 15.0(1)XA5
So, the new default is BW - priority %?  What is the best practice for reserving BW then?
Joseph W. Doherty Tue, 11/08/2011 - 16:12
Disclaimer
Posting
If I remember correctly, CBWFQ's default bandwidth reservation changed with 12.4(20)T, so your 15.0 version should be using HQF QoS.
Actually it might be BW - all defined bandwidths other than remaining, but I'm unsure.
You might just use defined bandwidths or straight percentages.
Marwan ALshawi Tue, 11/08/2011 - 13:56
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
You can consider using hqos with a shaper in the parent qos policy
Plz refer to the below document for more details
https://supportforums.cisco.com/docs/DOC-8373
Hope this helps
If helpful rate
Related Content
