Warning message
Asa 5505 Inside Network route to the Internet
Nov 9th, 2011
Hello Guys i have asa 5505 , so i wanna my inside network to access to the internet , so can you please give me idea how to route . my internet gateway is 155.155.155.1
: Saved
ASA Version 8.2(1)
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address 155.155.155.155.10  255.255.255.0
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 41.189.228.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto isakmp policy 5
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto isakmp policy 10
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:9d5a017ad820b32ca7a9f9e35f5a45f3
: end
cadet alain Wed, 11/09/2011 - 07:16
  • Purple, 4500 points or more
route outside 0 0 155.155.155.1
Regards.
Alain
ThomasMull9000 Wed, 11/09/2011 - 07:29
.Thank you for quick respond Alien
i add this but its not working . my inside hosts can't ping my internet route.
so please can i need some access list or NAT
cadet alain Wed, 11/09/2011 - 08:35
yes by default icmp is not inspected so you must add this:
inspect icmp
Regards.
Alain.
