zone based firewall - ftp
Nov 9th, 2011
I'm having an issue where ftp is allowed out, but is dropping on the way back in.
seeing
Dropping tcp pkt 209.95.232.144:20 => 192.168.0.11:62589
Does that mean an ACL is dropping and not the ZBF?
Julio Carvajal Wed, 11/09/2011 - 10:50
  • Purple, 4500 points or more
Hello Joseph,
have you the following command:
<br/>      -ip inspect log drop-pkt
And yes, the ZBF drop should look like this
%FW-6-DROP_PKT.
If you want you can post your running configuration with some changes of course because of security
Have a great day,
Julio
Joseph Chambers Wed, 11/09/2011 - 10:59
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 116
class-map type inspect match-all sdm-nat-user-protocol--1-2
match access-group 107
match protocol user-protocol--1
class-map type inspect match-any sdm-service-sdm-pol-NATOutsideToInside-1
match protocol http
match protocol https
class-map type inspect match-all sdm-nat-http-1
match access-group 108
match class-map sdm-service-sdm-pol-NATOutsideToInside-1
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 106
class-map type inspect match-any FTP
match protocol ftps
match protocol ftp
class-map type inspect match-all sdm-cls-sdm-pol-NATOutsideToInside-1-1
match class-map FTP
match access-group 120
--More--         class-map type inspect match-all sdm-nat-smtp-1
match access-group 104
match protocol smtp
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any SDM_WEBVPN
match access-group name SDM_WEBVPN
class-map type inspect match-all SDM_WEBVPN_TRAFFIC
match class-map SDM_WEBVPN
match access-group 110
class-map type inspect match-any CCP-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol h323
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
--More--          match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any all
match protocol tcp
match protocol udp
match protocol icmp
class-map type inspect match-all sdm-cls--1
match class-map all
match access-group name to_ezvpn
class-map type inspect match-all SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
--More--         class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 103
class-map type inspect match-all sdm-nat-https-2
match access-group 109
class-map type inspect match-all sdm-nat-https-1
match access-group 105
class-map type inspect match-all ccp-protocol-http
match protocol http
--More--         !
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-smtp-1
  inspect
class type inspect sdm-nat-https-1
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class type inspect sdm-nat-user-protocol--1-2
  inspect
class type inspect sdm-nat-http-1
  inspect
class type inspect sdm-nat-https-2
  inspect
class type inspect sdm-cls-sdm-pol-NATOutsideToInside-1-1
  inspect
class class-default
--More--         policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect CCP-Voice-permit
  inspect
class class-default
  inspect
class type inspect SDM_EASY_VPN_SERVER_PT
  pass
class type inspect SDM_WEBVPN_TRAFFIC
  inspect
class class-default
policy-map type inspect sdm-policy-sdm-cls--1
class type inspect sdm-cls--1
  inspect
class class-default
policy-map type inspect sdm-inspect-all
class type inspect sdm-cls-VPNOutsideToInside-1
--More--           inspect
class class-default
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  inspect
class class-default
  drop log
zone security LAN
zone security Outside
zone security out-zone
zone security in-zone
zone security ezvpn-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-ezvpn1 source in-zone destination ezvpn-zone
--More--          service-policy type inspect sdm-permit-ip
zone-pair security sdm-zp-out-ezpn1 source out-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-out1 source ezvpn-zone destination out-zone
zone-pair security sdm-zp-ezvpn-in1 source ezvpn-zone destination in-zone
zone-pair security sdm-zp-self-ezvpn-zone source self destination ezvpn-zone
service-policy type inspect sdm-policy-sdm-cls--1
interface Loopback0
description Do not delete - SDM WebVPN generated interface
ip address 192.168.1.1 255.255.255.252
ip nat inside
ip virtual-reassembly
interface Loopback1
--More--          ip address 192.168.52.254 255.255.255.0
interface Loopback5
ip address 192.168.57.254 255.255.255.0
interface Loopback6
ip address 192.168.58.254 255.255.255.0
interface Loopback9
ip address 192.168.61.254 255.255.255.0
interface FastEthernet0/0
description connected to EthernetLAN$ETH-LAN$$FW_INSIDE$$ES_LAN$
ip address 192.168.0.1 255.255.255.0
ip nat inside
zone-member security in-zone
no ip route-cache cef
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
--More--         interface FastEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address x.x.x.82 255.255.255.0
ip nat outside
zone-member security out-zone
duplex full
speed auto
crypto map SDM_CMAP_1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nonat interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.0.30 25 x.x.x.83 25 extendable
ip nat inside source static tcp 192.168.0.30 443 x.x.x.83 443 extendable
ip nat inside source static tcp 192.168.0.31 3389 x.x.x.84 3389 extendable
ip nat inside source static tcp 192.168.0.19 3389 x.x.x.85 3389 extendable
ip nat inside source static tcp 192.168.0.8 443 x.x.x.86 443 extendable
ip nat inside source static tcp 192.168.0.11 20 x.x.x.88 20 extendable
ip nat inside source static tcp 192.168.0.11 21 x.x.x.88 21 extendable
ip nat inside source static tcp 192.168.0.11 3389 x.x.x.88 3389 extendable
ip nat inside source static tcp 192.168.0.6 3389 x.x.x.89 3389 extendable
ip nat inside source static tcp 192.168.0.7 21 x.x.x.90 21 extendable
ip nat inside source static tcp 192.168.1.1 443 192.168.0.1 4443 extendable
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_IP
permit ip any any
ip access-list extended SDM_WEBVPN
permit tcp any any eq 443
ip access-list extended VPN
permit udp any host 192.168.0.1 eq non500-isakmp
permit udp any host 192.168.0.1 eq isakmp
permit esp any host 192.168.0.1
permit ahp any host 192.168.0.1
--More--         ip access-list extended to_ezvpn
remark CCP_ACL Category=128
permit ip any any
ip radius source-interface FastEthernet0/0
logging trap debugging
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 remark SDM_ACL Category=4
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
access-list 103 remark CCP_ACL Category=128
access-list 103 permit ip host 255.255.255.255 any
access-list 103 permit ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip 66.195.205.0 0.0.0.255 any
access-list 104 remark CCP_ACL Category=0
access-list 104 permit ip 216.82.240.0 0.0.15.255 host 192.168.0.30
access-list 104 permit ip 67.219.240.0 0.0.15.255 host 192.168.0.30
access-list 104 permit ip 85.158.136.0 0.0.7.255 host 192.168.0.30
access-list 104 permit ip 95.131.104.0 0.0.7.255 host 192.168.0.30
access-list 104 permit ip 117.120.16.0 0.0.7.255 host 192.168.0.30
access-list 104 permit ip 193.109.254.0 0.0.1.255 host 192.168.0.30
access-list 104 permit ip 194.106.220.0 0.0.1.255 host 192.168.0.30
access-list 104 permit ip 195.245.230.0 0.0.1.255 host 192.168.0.30
access-list 105 remark CCP_ACL Category=0
access-list 105 permit ip any host 192.168.0.30
access-list 106 remark CCP_ACL Category=0
access-list 106 permit ip any host 192.168.0.31
access-list 107 remark CCP_ACL Category=0
access-list 107 permit ip any host 192.168.0.11
access-list 107 permit ip any host 192.168.0.6
access-list 108 remark CCP_ACL Category=0
access-list 108 permit ip any host 192.168.0.8
access-list 109 remark CCP_ACL Category=0
access-list 109 permit ip any host 192.168.1.1
access-list 110 remark CCP_ACL Category=128
access-list 110 permit ip any host 66.195.205.82
access-list 111 remark CCP_ACL Category=4
access-list 111 permit ip 192.168.0.0 0.0.0.255 any
access-list 112 remark CCP_ACL Category=4
access-list 112 permit ip 192.168.0.0 0.0.0.255 any
access-list 113 remark CCP_ACL Category=4
access-list 113 permit ip 192.168.0.0 0.0.0.255 any
access-list 114 permit ip host 192.168.0.6 192.168.50.0 0.0.0.255
access-list 114 permit ip 192.168.0.0 0.0.0.255 192.168.52.0 0.0.0.255
access-list 114 permit ip 192.168.0.0 0.0.0.255 192.168.53.0 0.0.0.255
--More--         access-list 114 permit ip 192.168.0.0 0.0.0.255 192.168.54.0 0.0.0.255
access-list 115 permit tcp host 192.168.0.30 any eq smtp
access-list 115 permit tcp host 192.168.0.31 any eq smtp
access-list 115 deny   tcp any any eq smtp
access-list 115 permit ip 192.168.0.0 0.0.0.255 any
access-list 116 remark CCP_ACL Category=4
access-list 116 permit ip 192.168.0.0 0.0.0.255 any
access-list 120 remark CCP_ACL Category=128
access-list 120 permit ip any host 192.168.0.11
access-list 121 permit ip host 209.95.232.144 host 192.168.0.11
route-map nonat deny 10
match ip address 114
route-map nonat permit 20
match ip address 115
Julio Carvajal Wed, 11/09/2011 - 14:29
Hello Josheph,
Can you try the following please:
-     no class-map type inspect match-all ccp-insp-traffic
-     class-map type inspect match-any ccp-insp-traffic
I also would like you to apply the following command into your configuration:
Then send us the logs while the issue is happening.
Please let me know if this works.
Julio
Joseph Chambers Thu, 11/10/2011 - 12:51
that didn't fix it.
Never mind, I dropped in an ASA today.  Problem solved
Julio Carvajal Thu, 11/10/2011 - 12:55
Hello Joseph,
Sure, without the logs is almost impossible to solve this kind of issues.
Joseph Chambers Thu, 11/10/2011 - 16:19
No worries. Asa is so much easier to deal w vs zbf
Maykol Rojas Thu, 11/10/2011 - 20:26
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Just in case you wanted to know the reason, it is because the ZBF is not inspecting FTP, so the dynamic data channel (in this case port 20) is going to be dropped. In order to overcome this issue you need to inspect FTP, so the Firewall know that a data connection will come.
The command you needed was this:
inspect ftp
Anyways, I love the ASA, but ZBF is not a bad approach if you dont have enough budget
Mike
