POTS dial-peer trying to register with SIP Registrar
Answered Question
Nov 9th, 2011
Hi All,
I was setting up CUBE-SIP-to-SIP trunk for PSTN. This router is also set up for SRST and it has relevant dial-peers configured. After configuring this I saw following messages trying to send the register messages to registrar:as.nipt.telstra.com. The service provider saw those message as well. To stop this initially I shut down all the dial-peers and later I had to add "no sip-register" and after no shut I can see those messages have stopped. I am now wondering why this happened? Why these dial-peers were sending the messages? Is adding "no sip-register" a solution or just a work around.
Nov  8 16:36:58.242 ACST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:as.nipt.telstra.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.20.251.45:5060;branch=z9hG4bK5414D2
From: <sip:004........@as.nipt.telstra.com>;tag=4633F78-67F
To: <sip:004........@as.nipt.telstra.com>
Date: Tue, 08 Nov 2011 07:06:58 GMT
Call-ID: C21A9B6D-8E911E1-811C9CC9-B72173B1
User-Agent: Cisco-SIPGateway/IOS-15.2(1)T1,
Max-Forwards: 70
Timestamp: 1320736018
CSeq: 91 REGISTER
Contact: <sip:004........@10.20.251.45:5060>
Expires:  3600
Supported: path
Content-Length: 0
Correct Answer by rivasque about 5 years 3 months ago
Hello...
Adding the no sip-register is the solution on this, by default the gateway will try to register with SIP or gatekeeper depending on what you have configured any number on the configuration either on a DN or destination pattern.
The no sip-register is the solution on this.
Overall Rating: 3.8 (4 ratings)
Correct Answer
rivasque Mon, 12/05/2011 - 08:37
Hello...
Mustapha Arakji Wed, 02/22/2012 - 07:09
What about the VOIP dial-peers? I have a CUE with CME and a SIP Trunk, i can see the CUE pilots are trying to register with my SIP!!
rivasque Mon, 02/27/2012 - 05:36
Go ahead and add:
no register e164
on the oip dial-peers, taht will stop the registration messages with the Destination-pattern on they.
Habib Ahmad Tue, 12/04/2012 - 12:30
hello
when i do a no register e164, my sip service stops and the sip-ua config has to be re entered.
Line                             peer       expires(sec) registered P-Associ-URI
7039451007                       -1         2007         yes          // calls work when this is registered
81[2-9].........                       5          63           no              // dial peer trying to register
nz78au Tue, 12/04/2012 - 13:31
sip-ua config is used to register to your sip service provder. Without it or if you have incorrect sip-ua details the sip tries to register using pots dial-peer information and in some cases it was register but calls may not work as your service provider may reject the calls.
Habib Ahmad Tue, 12/04/2012 - 13:35
correct on the sip-ua config. what im stating is when i added the no register e164 under the voip dialpeers that keps sending register request, the confing under my sip-ua goes missing, so i have to add the credentials, the sip-ua address and port etc all over again and the calls start to work again.
nz78au Tue, 12/04/2012 - 14:13
I have not seen this behaviour on 2900 (IOS 15.1) and 2800 (IOS 12.4) series routers. What is your router model and IOS version?
