network command on cisco router
Answered Question
Nov 10th, 2011
Hi all,
I was reading about network command when we configure the Routing protocols like RIP or ospf.
it says network command does two things
what network to advertise to  other routers  and which interfaces it will advertise the network.
if we have 3 routers  , router a b and c
Router  A  has this config
2 interfaces one to WAN  and one to LAN  connection.
Router A  config
fa0/1  wan interface
ip address 70.x.x..x
fa0/0 lan interface
ip address 192.168.5.3
router rip
version 2
network 70.0.0.0
network 192.168.5.0
Router B  config
int fa0/0 connectes to router A
ip address 192.168.5.2
int fa0/1 connects to switch A on vlan 10
ip address 192.168.10.1
int fa0/2 connects to switch B on vlan 20
ip address 192.168.20.1
int fa0/3 connects to Router C
ip address 192.168.4.2
now we enable RIP on Router 2
router rip
network 192.168.5.0
network 192.168.10.0
network 192.168.20.0
network 192.168.4.0
Router C
int fa0/0
ip address 192.168.4.3   connects to Router B
router rip
network 192.168.4.0
now my question is router B has
network 192.168.5.0 it will advertise that to both Router A and C  right?????
Router A is directly connected to B  Router so it already knows about it right???
Router C  will came to know about Network 192.168.5.0  right ????? when Router B  advertise??????
So Now Router B will advertise network on both interfaces that connect to Router A and C  or only on interface that has ip address 192.168.5.2???
thanks
Correct Answer by cadet alain about 5 years 8 months ago
Yep that's it.
Regards.
Alain
Overall Rating: 5 (1 ratings)
cadet alain Thu, 11/10/2011 - 13:20
  • Purple, 4500 points or more
No it won't advertise it to A but it will listen for rip messages and send rip messages out this interface.
Yes for both routers this is a connected route
Yes exactly
it will advertise networks on all interfaces where rip is enabled due to network command if the interface is not passive and it will listen to rip updates on all interfaces enabled for rip due to network command But due to spli-horizon it won't advertise a route on an interface where it already received this route.
Regards.
Alain
mahesh18 Thu, 11/10/2011 - 14:15
Hi alain
Thanks for reply.
so this means that as Router A and B are directly connected so thats reason it will not advertise 192.168.5.0 to Router
A??
Correct Answer
cadet alain Fri, 11/11/2011 - 01:33
Yep that's it.
Regards.
Alain
mahesh18 Sat, 11/12/2011 - 22:36
Hi Alain,
Many thanks for good explanation.
Mahesh
