Warning message
WAP4410N : One network, Two SSID's...???
Nov 10th, 2011
Even though I am concerned about purchasing the WAP4410N because of its reported problems (some of which I've experienced myself), I have a customer who has an extremely small budget, but would like to add value to their network by offering WiFi at their location.  Because of their small budget, I'm forced to attempt a setup that goes outside of my usual best practices, and I have a question to ask those fimilar with the product.
They currently have a router that is not VLAN capable, and I was wondering if the WAP4410N could be configured to service one subnet with two SSID's, one of which would be configured in guest mode?  The desired end result would be a private WiFi network (company_net) where the managers can work and communicate with devices on the network, and a secure network (company_guest) where customers cannot talk to anything on the local network, and are restricted to internet only access.
Does anyone with experience with the WAP4410N know if this setup is possible?
Thanks In Advance,
-Ed
Overall Rating: 4 (1 ratings)
Sujoy Paria Wed, 12/07/2011 - 04:51
  • Cisco Employee,
Hi Ed,
           It is possible to create two SSID on the WAP4410N with same IP subnet & at the same time you can block the access to the first SSID (as per you example; company_net) to the second SSID (company_guest). You need to just enable the “Wireless isolation: (between SSID)” on the Wireless security settings in WAP4410N. With that configuration intercommunication between those SSID will not work.
Note: For different SSID you can choose different security mode as per your requirement.
Best Regards,
Sujoy Kumar Paria
Ed Melendez Wed, 12/07/2011 - 07:39
Thanks for replying Sujoy-
Will 'Wireless Isolation' also restrict wireless clients from communicating with clients on the LAN?
-Ed
Sujoy Paria Wed, 12/07/2011 - 23:30
  • Cisco Employee,
Hi Ed,
‘Wireless Isolation’ will restrict the communication between the users connected via Wireless LAN on SSID1 & SSID2  (as per the example; company_net & company_guest).
If on the same IP sub-network you are connecting some users via Ethernet cable then ‘Wireless Isolation’ will not block communication to those users (from both the SSID).
Best Regards,
Sujoy Kumar Paria
Related Content
