Warning message
XFP-10GLR-OC192SR – Anyway to enable port with absence of Rx light
Nov 11th, 2011
Hello netpro guru’s, just wondering if there is a way of enabling a XFP-10GLR-OC192SR without the presence of Rx light. Basically this port is being used to send traffic (using port mirroring) to a probe via a passive aggregation tap that doesn’t supply Rx light (hence the port doesn’t come up).
Equipment used is Cisco ASR9010, using code 4.0.1.
Thanks in advance.
Regards, Adrian
