Warning message
Auto Configuration file population
Nov 11th, 2011
Hi Folks,
I'm looking for the most effiencient and reliable way to load configuration onto 250 2911's. Here's the criteria; The devices will be set up in our lab and that is were the configuration will be carried out. they will all be using the same subnet. Obviously every configuration file will be different but large parts will be identical for every single device.
Is there a way to use dhcp to populate the IP addresses of the 2911's and then have some kind of process where a test switch or router pushes a configuration file to each node in that subnet?
It would be even better if we could push prepared indivdual config files to corresponding IP addresses but we can get a generic config file done I'd be happy
Ciaran
