How do I update my Cisco ASA 5505 firewall IOS?
Nov 12th, 2011
When I upgrade the ios on switches, I just create int vlan1 assign it an ip and subnet, then tftp to my pc that is plugged into the switchport using the download-sw command.
I am not sure how to do this on the asa.  Do I just plug my pc into port 0 which the documentation says is mapped to vlan 1 with and ip of 192.168.1.1?
I tried this by making my pc's ip 192.168.1.2 but am unable to ping the asa.  Do I have to change the security level or anything?
I am new to the ASA's
Maykol Rojas Sat, 11/12/2011 - 15:43
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Hi Mike,
Port 0 is the only port that is assigned to a different Vlan, you should plug your computer to any other port other than 0 and you will be able to reach the ASA using the IP address 192.168.1.1. Make sure thou that your laptop remains using and IP on the same subnet as the ASA firewall.
Try it out and let me know.
Mike
Related Content
