Warning message
Does the routers in GNS3 support WCCP/PBR?
Nov 13th, 2011
Dear All,
I am trying to setting up a wan on gns3 for testing wan and  training purpose. and wondering if the routers in gns3 support wccp and  PBR protocls , we are a wan optimization company and looking to test  our product in virtual environment.
I would appreciate if any one can feed me with this .and if it doesn't is there any simulator does ?
Thanks in advance
Ametto
cadet alain Sun, 11/13/2011 - 12:56
  • Purple, 4500 points or more
as long as you've got the correct IOS with the feature you're looking to test then it won't be any problem in GNS3.
So the answer is definitely yes for both features.
Regards.
Alain
Kishore Chennupati Sun, 11/13/2011 - 14:08
  • Gold, 750 points or more
Alain,
Did you simluate the ASR's(IOS-XE/XR) on the GNS3 by any chance? I know they use a linux kernel and you can use QEMU to sort of set it up etc. I have simulated Olive in Junipers using GNS3 but not ASR's
Kishore
cadet alain Mon, 11/14/2011 - 03:58
Hi Kishore,
no I didn't emulate those so I can't tell you if it's possible with QEMU.
Regards.
Alain
ametto123 Mon, 11/14/2011 - 02:16
Thanks Alain for the quick reply,
I am more into servers and vmware,
are the IOS free to download? which router do u suggest have the wccp feature in it ?
thanks
cadet alain Mon, 11/14/2011 - 03:57
no the IOS is not free and you can do it with a 2600 router.GNS3 doesn't support the newer 15 version IOS.
Regards.
Alain
cesar.aguirre Mon, 12/31/2012 - 08:47
Este IOs si soporta el WCC / PBR
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.0(1)M9, RELEASE SOFTWARE (fc1)
Cesar Aguirre
