Warning message
Unable to add Loopback interface
Answered Question
Nov 13th, 2011
Hi all,
i am trying to add loopback interface 0  and asisgn it IP address here is issue
2620Router(config-if)#  ip address 172.16.0.0 255.55.0.0
Bad mask 0xFF370000 for address 172.16.0.0
How can i fix this?
Mahesh
Correct Answer by cadet alain about 5 years 9 months ago
your IP didn't work because:
1) it was not a host IP address but a network or subnet IP
AND
2) your mask was incorrect: 255.55.0.0 it should have been 255.255.0.0 because in a mask you must have contiguous bits
which is not the case in 55( 00110111) and the message was giving you your wrong mask in hex representation
0xFF370000 is 255.55.0.0 in dotted decimal.
Provided point 1 was corrected you could have put any valid mask  for a subnet in which the IP was included like a /24 for example. But it's best practice and in some cases mandatory like in MPLS VPNs to give loopbacks a /32 mask.
Regards.
Alain
Correct Answer by Reza Sharifi about 5 years 9 months ago
Hi Mahesh,
172.16.0.0/16 is a network/subnet You need to assign a host address to the interface
try this:
interface Loopback0
ip address 172.16.1.1 255.255.255.255
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Sun, 11/13/2011 - 12:24
  • Cisco Designated VIP,
    2017 LAN
Hi Mahesh,
try this:
interface Loopback0
mahesh18 Sun, 11/13/2011 - 12:48
Hi Reza,
that worked can you please  explain me why my IP  does not work and urs worked?
thanks
mahesh
Correct Answer
cadet alain Sun, 11/13/2011 - 13:04
  • Purple, 4500 points or more
AND
Regards.
Alain
mahesh18 Sun, 11/13/2011 - 14:27
Many thanks again Reza and alain.
regards
mahesh
