SDM stops on startup "Discovering router hardware attributes"
Nov 13th, 2011
Hi, there I'm preparing for my CCNA Security and want to practice on SDM but unfortunately I can't open it.
My lab is Windows 7 Gns 3.7.4 Java 1.6.0_03 (it was told me that's the compatible one) IOS:  c3640-jk9s-mz.124-16.bin and SDM 2.5
My config is:
int fa0/0
ip address 172.16.1.254 255.255.255.0
no shut
exit
ip domain-name router.com
username test privilege 15 password test
ip http server
ip http secure-server
ip http authentication local
line vty 0 4
login local
transport input telnet ssh
privilege level 15
line cons 0
login local
transport output telnet ssh
privilege level 15
exit
crypto key generate rsa gen mod 1024
THE ISSUE:
1. using http won't pop up anything can't run on http
2. using HTTPS passes the popup windows but stops at:
"Please wait while sdm is loading the current configuration from your router.  Discovering router hardware attributes."
As the picture shows:sdm.png
And then nothing happens.
I'm playing around with it for a few days, hands up have no more ideas what to do...if you have any ideas please share it - really wanna check the SDM before exam.
Thanks.
zoltanszasz Fri, 11/25/2011 - 19:06
what i would do next is to SDM another router with different IOS image to see if that works.
cadet alain Sat, 11/26/2011 - 11:05
  • Purple, 4500 points or more
Can you try this command:
ip http timeout-policy idle 600 life 86400 requests 10000
Regards.
Alain
Related Content
