LMS 3.2.1 changing smtp server
Answered Question
Nov 14th, 2011
Running lms 3.2.1   CS 3.3.1  on Windows 2003
I need to point the LMS server to a new mail relay, but when I make the change in
CS->SERVER->Admin->System Preferences  smtp server
It claims to have made the change successfully but the old IP address remains.
I made a successfull change days before.  Any help/thoughts appreciated?
Correct Answer by AFROJ AHMAD about 5 years 9 months ago
Hi John,
Yes , you can edit the regdaemon.xml file directly to replace the ip address and  that will fix the issue.
Note :Before you make the changes in the file , keep a backup of the file.
Afroj
Overall Rating: 5 (1 ratings)
AFROJ AHMAD Tue, 11/15/2011 - 00:10
  • Cisco Employee,
Hi John,
Kindly send me the regdaemon.xml file (NMSROOT\MDC\etc)
Afroj
john.caterino Tue, 11/15/2011 - 04:08
Afroj,
          Thank You for the response.  Unfortunately I am unable to provide the regdaemon.xml as this is a closed system.
The  regdaemon.xml file shows the old ip address that is displayed in the gui, however when I try to update it through the gui, the smtp.log shows successfull validation of the smtp service using the updated ip address.
I understand that this may not be resolvable without me providing this file and I can open a TAC case if necessary.
Can I edit the regdaemon.xml file directly to replace the ip address?
Correct Answer
AFROJ AHMAD Tue, 11/15/2011 - 04:13
  • Cisco Employee,
Hi John,
Afroj
