Warning message
1 on 1 NAT and port forwarding not working...
Nov 15th, 2011
This is not the first time i will configure over the internet access to a local server but this particular one is giving me a major headache and i thought to share the config with anyone who can help ppoint where the problem may be. While my NAT transalations seem to be working, when i attempt to browse the public IP, i am supposed to be routed to the local server, but this doesnt happen and i just get a blank page on my web browser. Please see config below:
J#sh run
Building configuration...
Current configuration : 5368 bytes
version 12.4
no service pad
hostname J
boot-start-marker
boot-end-marker
enable secret 5 $1$aNyD$j4lIgFXI84Xp9RR5dzwVk0
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime 1
crypto pki trustpoint TP-self-signed-1366127775
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1366127775
revocation-check none
rsakeypair TP-self-signed-1366127775
crypto pki certificate chain TP-self-signed-1366127775
certificate self-signed 01
  30820255 308201BE A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31333636 31323737 3735301E 170D3032 30333031 30303533
  35315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33363631
  32373737 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CCDC 58E9E078 C978DBC5 CD0D97A0 6B506E2B 4843F38C 578721BF 285EC7BF
  F3700E9C FAD9233C A4CC95F6 F29FE5CD 4664F85F 862FB879 1255F21B 725A2773
  E1E4BEC0 632A7FFD C383F08E D5FAA4FC 4558BE6B 1B383D7E 19A871F6 3BAB9BAE
  B7CB84BB 510A09A3 FA260893 B0BD5AB1 027C97C6 2B2D2B6C AE2683FC AC3015B6
  CE8F0203 010001A3 7D307B30 0F060355 1D130101 FF040530 030101FF 30280603
  551D1104 21301F82 1D4C494E 45545241 4C455F41 424A2E6C 696E6574 72616C65
  2E6C6F63 616C301F 0603551D 23041830 16801434 DD7F3F33 59A951AA 1BBBF414
  59302323 10248530 1D060355 1D0E0416 041434DD 7F3F3359 A951AA1B BBF41459
  30232310 2485300D 06092A86 4886F70D 01010405 00038181 00A9C9DF 5D2F2042
  0AA151FF 72F7D52A 8244C102 4AEDDB6E C7FBA201 A283D693 5F5E9376 0D15E7FE
  EBB804A5 C08F6CA1 A416118F D5A06864 EF242404 091F2FFE 3F85B0DE 98E1F747
  AC5FBBDE 1E27AE14 64D71B5F A1A48EC7 90882BD2 C3617E7C 8D6426A0 EDA23AB1
  32350B15 5E2489F6 018A76A0 3E1595DA 6797723E 563D268A 66
            quit
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.111 192.168.1.254
ip dhcp pool J
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   domain-name linetrale.local
   dns-server 192.168.1.254
no ip bootp server
ip domain name linetrale.local
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set AES-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set 3DES-SHA-compression esp-3des esp-sha-hmac comp-lzs
crypto ipsec transform-set AES-SHA-compression esp-aes esp-sha-hmac comp-lzs
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
switchport access vlan 101
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN_FW_OUTSIDE$ETH-WAN$
ip address x.x.x.x 255.255.255.192
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip nat outside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1380
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan101
description LAN_FW_INSIDE
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip nat inside
ip route-cache flow
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 y.y.y.y
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.243 80 x.x.x.x 80 extendable
! x.x.x.x is the public IP
access-list 1 remark INSIDE_IF=VLAN101
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
no modem enable
transport output telnet
speed 115200
line aux 0
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
privilege level 15
terminal-type moni
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Any help will be really appreciated.
Femi
ajay chauhan Tue, 11/15/2011 - 07:22
  • Silver, 250 points or more
Port forwarding statement seems to be Ok . have you performed basic troubleshooing ? checking if the port 80 is Up and running on server and got connectivity from router .you can also verify doing telnet on port 80.
femi.agboade Tue, 11/15/2011 - 10:32
Hi, thanks for your comments. I can telnet on port 80 fine. When I am on the LAN, I can browse to the server's local IP, however, when I attempt to navigate from outside the network through the 1 on 1 NAT, the browser just keeps trying to load and gets stuck there.
ajay chauhan Tue, 11/15/2011 - 10:59
Can you please also test this-
remove-
add
ip nat inside source static tcp 192.168.1.243 80 interface FastEthernet4 80 extendable
and try to access using http://interfaceip from outside.
Ajay
femi.agboade Tue, 11/15/2011 - 11:16
I tried this before but the issue remains the same. I just tried it again and same thing. Note that when specifying an interface instead of an IP, you cannot use the option "extendable" as it is not available.
I think the problem may be firewall or access list because the page does attempt to open, but the browser just gets stuck constantly trying to load the page.
