11-15-2011 10:58 AM - edited 03-07-2019 03:24 AM
I just read the Removing and Installing CompactFlash Memory Cards in Cisco 2800 Series Routers instructions and there was nothing said regading powering down the router. Are these CompactFlash cards hot swappable??
Solved! Go to Solution.
11-15-2011 11:27 AM
Jim
You mean the flash cards that go into one of the external slots in the chassis ? If so the yes you can simply remove/plug in these cards, there is no need to power down the router.
Jon
11-15-2011 11:27 AM
Jim
Jon
11-15-2011 11:51 AM
Thank you, Jon. I was just a little surprised especially since they have all of the ESD warnings.
I appreciate your response.
Best regards,
Jim Stover
