RV042 VPN QuickVPN, vs standard Cisco VPN Client
Nov 15th, 2011
I have a RV042 router setup with Client to gateway VPN access, and am connecting with a W7 PC running QuickVPN. We have many PC's that already have the standard CiscoVPN client on them, is it possible to configure the RV042 to allow these clients to conenct? I'm not sure how to get the Mutual authentication to work, or how to import the PEM certificiate into that client. It seems to allow it to import, but I can never select it.
Any suggestions?
speedin2000 Mon, 11/21/2011 - 04:31
Hi, is this not possible to do? Or do we have to use the quickVPN clinet with this router?
riroe Mon, 11/21/2011 - 04:44
Hello---You will not be able to configure the Cisco VPN with the RV042. You will have to use the QVPN client for this Router.
THANKS
Rick Roe
Cisco Small Business Support Center
