Warning message
UC540 expansion port
Answered Question
Nov 15th, 2011
Can a Cisco SG300-28P switch be used with the expansion port on a UC540W?
Correct Answer by David Trad about 5 years 9 months ago
Marcus Casimir wrote:
"Friends don't let friends use SIP!"
Of course they do Friends don't let Friends stay in a proprietary world, friends encourage other friends to work within an open socieity (LONG LIVE FOSS!!)
Errr back on topic
Devin make sure you upgrade your SG/SF to version 1.1.8, I have had the best success with this revision and it is the latest (Last time I looked). But here is a hint, make sure that within CCA you go to the SmartPort configuration of that switch (Right Click on it) and set all the ports up to "IP Phone+Desktop" and the ports that is plugged into the expansion port set for "Switch" and make changes to the other ports that require it to their appropriate settings.
The SF/SG series switches do not seem to accept the changes as fluid as the ESW range did, they are pretty good switches, don't get me wrong, but their interoperability with CCA/UC still seems to be a little off.
Cheers,
David.
Correct Answer by daviddun about 5 years 9 months ago
Be sure to upgrade the firmware on the switch and it will work with no
problems
David Dunlap
SBSC UC Support Engineer
CCNA, SCCP SIP certified
& CCNA-Voice
10:00am to 7:00pm EST
Monday to Friday
[email protected]
Office +1 (866) 606-1866 ext. 601050
Fax +1 (866) 875-3916
Cisco Steps to success for UC500 platform
https://supportforums.cisco.com/docs/DOC-16634
Cisco SMB support forum
https://supportforums.cisco.com/community/netpro/small-business
Cisco Technical Enablement Labs
https://supportforums.cisco.com/docs/DOC-9836
Partner CVENT Calender
4efb&t=http%3a%2f%2fwww.cvent.com%2fEVENTS%2fCalendar%2fCalendar.aspx%3fcal%
3d313c653e-5061-464b-9bc8-56ab83b20f47&s=%3cimgborder%3d%220%22src%3d%22ht
tp%3a%2f%2fcustom.cvent.com%2f7A5FE47695D247ABA545F93364B0665E%2fpix%2f49e30
e3eb8074b1bb95f4dacf65eaa42.JPG%22+alt%3d%22%22%2f%3e> Description:
Description:
http://custom.cvent.com/7A5FE47695D247ABA545F93364B0665E/pix/49e30e3eb80...
Correct Answer by mcasimirc63 about 5 years 9 months ago
Yes.  The 200 and 300 series are supported via CCA also.
Overall Rating: 5 (3 ratings)
Correct Answer
mcasimirc63 Wed, 11/16/2011 - 04:04
  • Silver, 250 points or more
Correct Answer
daviddun Wed, 11/16/2011 - 05:45
  • Bronze, 100 points or more
problems
David Dunlap
& CCNA-Voice
Monday to Friday
[email protected]
Description:
mcasimirc63 Fri, 11/18/2011 - 12:56
problems
David Dunlap
& CCNA-Voice
Correct Answer
David Trad Mon, 11/21/2011 - 15:06
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Errr back on topic
Cheers,
David.
