Can't ping anything from a VPN client - ASA 5510
kevin.woodhouse
Hi All,
I’ve seen similar posts to this problem and I still haven’t managed to crack it so I thought I’d try my own post. I have a VPN client running on a laptop connected a DSL circuit. The VPN client is configured correctly for an external address on another firewall, this external firewall passes through ISAKMP / IPSEC to an ASA where it terminates. The client authenticates and gets an address from the client pool (VPNCLIENTS – 10.2.16.x / 24) and the tunnel completes with no problems. From the internal ASA I can ping any internal network behind the 10.0.3.240 interface (INSIDE) and I have a route on the inside network to get to the 10.2.16/0 clients to point to this address (10.0.3.240). All good so far.
Now the problems begin. I cant ping anything from the VPN clients (10.2.16.0) network to anywhere, I cant ping any interface on the ASA or any internal network. I also cant ping the client from the ASA and therefore not from the internal network either. This configuration is bare bones configuration so I don’t even have the NAT exception rules added. Looking for advice to get this to work. Network diagram attached too.
interface Ethernet0/0
nameif outside
security-level 0
ip address 192.168.40.10 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 0
ip address 10.0.3.240 255.255.254.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip any 10.2.16.0 255.255.255.0
pager lines 24
logging enable
logging buffered informational
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool VPNCLIENTS 10.2.16.5-10.2.16.250 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-525.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
no threat-detection statistics tcp-intercept
route outside 0.0.0.0 0.0.0.0 192.168.40.100 1
route inside 10.0.0.0 255.0.0.0 10.0.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 20 set pfs group1
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
group-policy testvpn internal
group-policy testvpn attributes
dns-server value 10.31.2.189
vpn-tunnel-protocol IPSec
default-domain value xxxxxxxxxxx
username testvpnuser password xxxxxxxxxxx encrypted privilege 0
username testvpnuser attributes
vpn-group-policy testvpn
username admin password GeamAtCaplZpZvZJ encrypted
tunnel-group testvpn type ipsec-ra
tunnel-group testvpn general-attributes
address-pool VPNCLIENTS
default-group-policy testvpn
tunnel-group testvpn ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map global_default
inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:c7487f1fbd0ca1d6fec057ef8ae2600f
acomiskey
Level 10
Level 10
Kevin,
My first recommendation would be to use another network for your vpn clients. You don't want it to overlap with your inside networks. Use something outside of 10.0.0.0/8 since you have a route in the ASA for this which points inside.
Thanks for the response.
Upon further investigation it seems echo requests destined to internal hosts are getting there however the replies are not getting back to the client. Could this be a simple case of traffic not originating from an inside to outside interface. I'm still not sure where VPN client traffic originates. the client pool is from the ASA however is traffic from this subnet originating from the client or from the ASA itself when the VPN is connected. ??
Good point about the client subnet and I will change it, there is a more specific route to this subnet though and that seems to be working fine, do need to change it though.
UPDATE:
I can see ICMP traffic from an internal host hitting the ASA however no traffic is seen at the other end of the tunnel on the client, can anyone suggest why traffic destined for the client is not being pushed down the tunnel ??
