Warning message
Wireless Controller connectivity to Nexus 2k
Nov 17th, 2011
I recently moved a 4402 Wireless LAN Controller off of a 6509  connection and onto a Nexus 2k connection. The config on the 6509 for  the WLC was as follows:
interface GigabitEthernet2/2/32
description ESC-WLC-1 Wireless LAN Controller
switchport
switchport mode trunk
mls qos trust cos
spanning-tree portfast edge trunk
When I configured the 2k FEX for connectivity, I entered the following comparable config:
int e101/1/23
spanning-tree port type edge trunk
I  was not able to get connectivity to the WLC. The WLC was set to trunk  and the interface was up, but even when I issued a show vpc consistency  parameters on that interface and all looked good, no connectivity.
Here are some of my log captures:
2011 Nov 11  07:39:24 ESC-NX5010-1 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs  1-5,10,51,100-112,120,155,201-202,251-252,255,302,307,310,320,1109 on  Interface Ethernet101/1/23 are being suspended. (Reason: Co
mpatibility check failed for port mode)
2011 Nov 11 07:39:24 ESC-NX5010-1 %ETHPORT-5-IF_UP: Interface Ethernet101/1/23 is up in mode trunk
2011 Nov 11 07:46:22 ESC-NX5010-1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on [email protected]/1
Does anyone know if there is anything special on the Wireless LAN Controller that needs to be configured?
Thank you,
Bobby Grewal
Michael Kim Fri, 11/18/2011 - 14:18
We had a similiar issue between our 6509 and our Nexus 5010.  Turned out to be an issue with pruning on our Port Channel.
do a sh run int trunk and check vlan prunning.
Good day
