UCS fabric-interonnect setup issue
Nov 17th, 2011
I am kind new to the UCS configuration arena. I got a complete setup with a Blade Chassis and two N10-6100 fabric interconnect to it. The setup was used earlier. When i brought it to our lab i need to change the ipaddress that it previously has. I connected through the console, but the cli seems very different from Nexus 5000 and MDS 9500 series switches from cisco. I could not even change the ip address. If anyone kind enough to show me some the way or some documentation i will be greatful. Fundamentally i want to change the ip address first and then some thing more.
I am giving some info from the setup that i have.
cisco-A-A(local-mgmt)# show version
System version: 1.4(1i)
I collected a UCSM CLI guide from net, where it says to change ip address use the following steps:
scope fabric-interconnect a
set out-of-band ip ip-address netmask netmask gw gateway-ip-address
When i tried on my system, it gave the following error.
cisco-A-A# scope fabric-interconnect a
Software Error: Exception during execution: [Error: Timed out communicating with DME]
Additionally i looked at the cluster state too.
cisco-A-A# show cluster state
Cluster Id: 0x77b2297e0a0711df-0xbfe7000decf4ca84
A: UP, ELECTION IN PROGRESS (Management services: UP)
B: UNRESPONSIVE, INAPPLICABLE, (Management services: UNRESPONSIVE)
INTERNAL NETWORK INTERFACES:
eth1, DOWN
eth2, DOWN
HA NOT READY
Peer Fabric Interconnect is down
No device connected to this Fabric Interconnect
WARNING: Failover cannot start, device configuration is incomplete
These are some info from my switch. If some one throw some light, it will be very helpful.
Robert Burns Thu, 11/17/2011 - 17:36
In order to change the IP of an existing HA UCS system, the DME & HA cluster must be online.  For this you need the cluster links (L1 & L2) connected between the two 6100's and a Chassis connected with at least one link to each IOM.
One this is all connected, your cluster state should show you "HA Ready" and you can then change your IP as detailed above.
Robert
niranjandas Thu, 11/17/2011 - 18:12
Thanks for the info on the topic. Could you pleas add the following info if you are aware ?
1. If i change only ip address am i good?
2. There seems to be 3 ipaddresses for mgmt port, 6100-A,  6100-B and virtual mgmt ip. Do i have to change all 3 ? Also which ip ( i mean 6100-A mgmt, 6100-2 mgmt or virtual ip) is used to communicate to the UCS system?
Thanks again.
Robert Burns Thu, 11/17/2011 - 18:17
IF you want to have an HA system (dual FI's) then you need 3 IPs - Fab Interconnect A, B and the Virtual IP.  Assuming your cluster is online, you can change all 3 addresses to the approrpriate subnet and you'll be fine.  You'll likely need to do this via the console as your may not able to reach the VIP via IP in the new subnet yet.
For HA mode, each FI has a management IP, and the VIP is used for UCSM access which floats between either FI A or B depending on which one is primary.
For standalone mode, you only need one address.
Robert
niranjandas Thu, 11/17/2011 - 18:47
Again thanks for the info provided. What is the exact command for changing ip address? Does UCSM stands for UCS manager?
Robert Burns Thu, 11/17/2011 - 19:02
Yes.  You had the commands correct above.  You scope to each FI and set the out-of-band management IP.
You can set the cluster IP (VIP) by scoping to "system" and setting the virtual-ip.
There's a couple posts on here detailing it, search my name and you'll find it.
Robert
Related Content
