Importing SSL cert from Microsoft Exchange Server to ACE
Nov 17th, 2011
Dear All,
            My customer has SSL certificate already installed on microsoft exchnage 2010 servers and now wanted to import that certificate to cisco ACE4710.
Can someone help me to trace the exact procedure to import the SSL Cert to ACE from microsoft exchange server and how about the KEY, from where I should get the KEY to cross verify for SSL Cert?
If sample configuration is available, then it will be great help.
Thanks in advance.
Ahmed...
ahmed.gadi Fri, 11/18/2011 - 10:31
Thanks Marko,
                     Tomorrow i will be visiting the customer and will update you...
Ahmed...
Related Content
