Using Appliance Ports for NAS
Nov 17th, 2011
Hey all connecting a NAS to UCS. Would like to plug in directly to FI’s using the Appliance Port option.
Are the steps basically
  • Turn on Ports use as Appliance Ports
  • Make PIN Group through Appliance Ports (this will only be one port per FI, I am guess Port-Channels can be used if NAS supports that?)
  • Make VLAN internal to UCS
  • Make vNIC Template and use newly created VLAN and PIN Group
Boom!
Right?
Thanks!
Craig
niranjandas Mon, 11/21/2011 - 17:38
Can you please specify what kind of devices are you going to connect to these appliance ports ? I mean are they going to be FCoE target or iSCSI target?
