Warning message
basic IPV6 setup question
Nov 17th, 2011
I am experimenting with IPV6 and have three devices in my test network.  They are setup as follows:
UC520 using BVI:   FD:0:0:1::1/64
Windows Server1:  FD:0:0:1::5/64
Windows Server2:  FD:0:0:1::6/64
I am using the following commands on the Cisco
ipv6 unicast-routing
ipv6 cef
int BVI100
  ipv6 address FD:0:0:1::1/64
  ipv6 enable
The Windows servers can ping each other, the Cisco can ping itself.  However I can't get pings from either Windows server to the Cisco.  I also tried pinging the Cisco using link-local IP but that doesn't work either.  Seems like I am missing something very basic, or so I hope.
Any ideas?
Overall Rating: 4 (4 ratings)
cadet alain Fri, 11/18/2011 - 00:54
  • Purple, 4500 points or more
Can you ping a server from Cisco device and then do a sh ipv6 nei and also sh ipv6 int bvi100.
Regards.
Alain
DIEGO ALONSO Fri, 11/18/2011 - 05:27
Here's what that looks like:
UC520#
UC520#ping fd:0:0:1::1
Sending 5, 100-byte ICMP Echos to FD:0:0:1::1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/4 ms
UC520#ping fd:0:0:1::5
Sending 5, 100-byte ICMP Echos to FD:0:0:1::5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
UC520#sho ipv6 nei
UC520#sho ipv6 int bvi100
BVI100 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::21C:58FF:FEE4:52A0
  No Virtual link-local address(es):
  Description: Test LAN
  Global unicast address(es):
    FD:0:0:1::1, subnet is FD:0:0:1::/64
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FFE4:52A0
  MTU is 1500 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  ND DAD is not supported
  ND reachable time is 30000 milliseconds (using 30000)
  Hosts use stateless autoconfig for addresses.
UC520#
stmillet Mon, 11/21/2011 - 01:35
  • Cisco Employee,
I had a similar behavioural issue with my setup at home when trying to setup my Dual stack ADSL service.
I found it worked once the following had been enabled
bridge irb
bridge 100 route ip (where 100 is the bridge group being configured)
I will add that IPv6 is not supported on BVI where one of the points is a dot11 radio (as per the bug notes supplied). I did get this working between the LAN switchports and the DSL interface.
Also as an aside if I can comment on the addressing you are using, I would recommend a change as you are using non IANA ratified address space.
FD:0:0:1::1 is infact 00fd:0000:0000:0001::1. (leading zeros stripped) which is reserved by IANA. I assume you are attempting to use the Unique local address scope and your address should infact be:
fd00:0:0:1::1/64
I hope this helps
DIEGO ALONSO Fri, 11/18/2011 - 05:29
My IOS is on the bug list.  I am running 15.0(1)XA2.
So I will certainly try to get it upgraded.  However is what I am having truly a routing issue?  I am not trying to route per se, my device only has one int with IPV6.  I am merely trying to communicate on the local LAN.
Rgds,
Diego
Marcin Latosiewicz Sat, 11/19/2011 - 08:58
  • Cisco Employee,
Diego,
What you describe (ping between windows hosts works, but not to/from router) means that bridging is working but routing is failing.
I'd give upgrade a try and report back (maybe some issues we don't see).
Marcin
DIEGO ALONSO Mon, 11/21/2011 - 06:12
Thanks to all who gave helpful suggestions.  In the end the problem was simple.  Basically I am an idiot.  I was enabling IPV6 on BVI100 which is my voice VLAN but the servers are in the data LAN!!  So I moved the IPV6 to BVI1 and everybody can talk to everybody now.
I upgraded to 15.1(2)T4 before I realized my stupidity so I don't know if I was being affected by the bug or not.  Also would like to thank stmillet for pointing out that I was using 00fd instead of what I meant to use which is fd00 so I did fix that also.
Thank you.
Diego
