11-17-2011 05:42 PM
Renaming admin user account
In OrganizationDesigner, is there a way to change the name of the admin account so that it appears friendlier in the logs/history?
11-17-2011 05:42 PM
No one is using the admin login; however, the system uses this account to record messages such as ("An email has been sent...", "... has completed task.", etc..). Can this account name be changed.
11-17-2011 05:42 PM
We would also like to change this from "admin", as our auditors feel this is too explicative and would prefer a different name. Is it possible?
11-17-2011 05:42 PM
I'll answer your question with another question: why are people logging in as admin? That should really be reserved for truly administrative functions, and not doing stuff with service forms that gets written to logs/history. It is very easy to create additional accounts that have identical privileges to the admin user (simply put a user in the Site Administration organization or give them Site Administration role). That way whatever names and login information you assign to these users would show up in
11-17-2011 05:42 PM
I think you would be ok with changing admin's lastname and firstname.
11-17-2011 05:42 PM
Our site is running 2008.3
Yes this is possible...we changed it at our site. It requires a database SQL to be executed. disclaimer: Our admin account has a personid = 1...not sure if this is by default...i believe it is.
To check, run: "select* from dirperson where personid = 1"
this should retrieve the admin account.
To update the first and last name:
update dirperson set firstname = '****' where personid = 1
update dirperson set lastname = '****' where pers
