Warning message
RequestCenter Select Queries
Nov 17th, 2011
Anyone in this group have any experience with select queries against the RequestCenter DB? I know that this is not generally supported, but we ocassionally have use cases where we need to retrieve transaction data in a finer grained format in real time.
We have numerous SQL routines in our library (simple selects all -- of course), but there is a specific case that I haven't been able to solve yet. If there are any tech resources out there with good knowledge of the schema I'd be very interested to exchange ideas.
Mihir Mihir Thu, 11/17/2011 - 17:49
Hi Doug,
We occassionaly do run SQLs againgst RequestCenter DB to generate some very specific reports demanded by end-users. Let me know what data you are looking for to pull up from DB.
-Mihir
Doug Pinkston D... Thu, 11/17/2011 - 17:49
I was looking for this, by serviceId.
Submitted Date
Approved Date
Completed Date
Time to Approve
Time to Deliver Once Approved
Total Time from Submit to Completed
For services with due date during a 30 month window that were completed, but not cancelled
Emir E Thu, 11/17/2011 - 17:49
The reporting packages should be able to help you out with this
This should get you started:
select r.RequisitionId,
  s.Name            as "Service Name",
  r.createdOn       as "Created Date",
  case when r.Statusid = 0 then 'Preparation'
 when r.Statusid = 1 then 'Ongoing'
 when r.Statusid = 2 then 'Closed'
 when r.Statusid = 3 then 'Cancelled'
 when r.Statusid = 4 then 'Rejected'
 when r.Statusid = 5 then 'Delivery Cancelled'
 else 'Unknown'
  end As Status,
  rb.FirstName || ' ' || rb.Last
Thanks so much for your help on this! This is where I got to, but it looks like your queries will do the trick. Thanks again.
select
TxRequisition.RequisitionID,
DefService.Name,
TxRequisition.StartedDate as SubmittedDate,
TxRequisitionEntry.StartedDate as ApprovedDate,
TxRequisitionEntry.DueDate,
TxRequisition.ClosedDate,
DATEDIFF( day, TxRequisitionEntry.StartedDate, TxRequisition.ClosedDate ) as DeliveryTimeDays,
TxRequisition.ActualDuration/10 as TotalTime, /* b
Doug,
txActivity, txProcess and txRquisition tables should help you get all the above information.
 txActivity.PerformerID - Actual Approver
txActivity.StartedOn - Date Started
Related Content
