Warning message
Solution for purging/archiving old messages from ServiceLink
Nov 17th, 2011
Hello there,
We're looking for some advice on how to purge or archive old messages from ServiceLink.  We're looking to retain one month's worth of data.
Is it possible to do this?
Many thanks.
Angelo S. - Dom... Thu, 11/17/2011 - 18:07
what version of RC are you running?   The maintenance scripts should be included with later releases under the parent installation directory... (\\newScaleXX\schema\util\slcleanup\)
Meghan Williams Thu, 11/17/2011 - 18:07
Thank you for your response, Angelo.
We've found the maintenenance scripts. Thanks for pointing us in the right direction!
