SpyLogger
Nov 17th, 2011
SpyLogger
What is SpyLogger used for?
Original Exception:
Error Message: SRVE0207E: Uncaught initialization exception thrown by servlet
Error Code: 500
Target Servlet: action
Error Stack:
java.lang.NoClassDefFoundError: com/newscale/jdbcspy/SpyLogger
Error Page Exception:
Error Message: com/newscale/jdbcspy/SpyLogger
Error Code: 0
Target Servlet: null
Error Stack:
     at com.newscale.jdbcx.base.BaseDataSource.setLogWriter(Unknown Source)
Emir E Thu, 11/17/2011 - 18:08
Thanks Enrico.
The issue is when you have Robust debugging (*=finest) enabled via WebSphere. Its trying to log the JDBC calls and it fails calling the class resulting in full outage of the system.
Enrico Pagayucan Thu, 11/17/2011 - 18:08
Emir, from our Engineering team:
"DataDirect Spy is a special debugging library for the DataDirect drivers. It can record all driver interactions at a very fine level. It is not enabled by default [and is not currently used by RequestCenter].
Is there a requirement to set debugging to *=finest? Does the next higher level of debugging detail meet your needs?
Related Content
