If you remove a rule in your source and try to modify your target to remove the rule, the catalog deployer will not remove it in the target.
Trying to update an active form component from source to target by using Catalog Deployer.
On first delpoyement, your source (Development) has one rule. After the first deployment, you source (Dev) and target (Prod) each have one rule. Next, you remove the rule in your source (Dev). When you try to deploy again, the rule will NOT be removed in your target (Prod). It will also not be removed from the active form behaviour.
Does anyone know a way around this without manually update your target. Is there a way the catalog deployment can be created so it takes into account rules that were removed in the source?
