3725 as a pstn/frame-relay simulator
Nov 17th, 2011
Looking at INE topology for the ccie voice lab setup, I see that they used 3725 as a PSTN and Frame-Relay switch. I also see on their site the following
modules they used in 3725 router
(Qty 2) VWIC-2MFT-T1
(Qty 1) VWIC-2MFT-E1
(Qty 1) NM-HDV
(Qty 2) PVDM-12
Also looking at the specification of 3725 router it has the following
3 VWIC/WIC (data only)
Comparing the modules used by INE and the specification of 3725 router, does this support both PSTN and FRAME-RELAY capabilities? I ask because the
single NM-HDV will be combined with one VWIC-2MFT-E1 or T1, but how about the remaining two VWIC-2MFT E1 or T1 if INE only used a single NM-HDV?
Because the built in slots on the 3725 router supports the VWIC-2MFT-x1 but in DATA mode only, meaning FRAME-RELAY support only and not PSTN (voice).
Base on my understanding on the modules and 3725 router, to support both PSTN and Frame-Relay it should have this modules
(Qty 2) NM-HDV         --> One for VWIC-2MFT-T1 and one for VWIC-2MFT-E1
(Qty 6) PVDM-12        --> Four for one NM-HDV and two for the other NM-HDV
Please correct me if I'm wrong and if INE modules for PSTN/Frame-Relay is sufficient
warquezho0612 Fri, 11/18/2011 - 00:34
Update:
I think INE is correct!
I came to realize that when you use NM-HDV on 3725 router and put some PVDM-12 (probably 2 at most) you can use the Three Integrated WAN Interface Card (WIC) slots on it for Voice traffic! So you can now use 3725 router both for PSTN Simulator and Frame-Relay
Can anyone confirm this?
