Warning message
Unity to Exchange 2010
Nov 18th, 2011
Good Morning
I know Unity gets its subscriber information from the telephone number field in Active Directory, an this be changed to point to another field in AD, if so how?  The reason I ask is that we are soon to be upgrading our Call Billing/Logging system and it will get its information from the Telephones/IP Phone/Other field.  Can Unity also get its information from here?
Pete
Bradford Magnani Fri, 11/18/2011 - 08:01
  • Cisco Employee,
Unfortunately that's the only field that Unity looks at.
However, Unity Connection 7.x+ gives you more flexibility with LDAP integrations as to which field you want to look at for extensions when importing users.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/gui_reference/guide/7xcucgrg100.html#LDAP_Directory_Configuration
Hope that helps,
Brad
