Dial-up connection
techeleccmd1775
I am trying to configure dial backup between two Cisco routers. When the remote router dials into the central router, you can hear the central router answer, but it does not begin the handshake until two or three seconds pass. During this time, the remote router drops the connection.
How do you fix this?
Any help would be very much appreciated!!!
10 Replies 10
Are you using PPP ?
If yes, can you post the debug ppp negotiation and debug ppp authetication and debug dialer results.
Smitesh
Yes I am using PPP. I will post the output from these debugs later today..
Thank you,
Here are the debug outputs you requested. When the remote router dials out and connects to the headend router, you can hear the headend router answer, but it seems to take too long to begin negotiating and the remote router just disconnects.
You can hear the same thing if you call the dial-up number using a phone. The router answers but then there is a pause of a couple of seconds before you hear any modem tones…
debug ppp neg
National#debug ppp negotiation
PPP protocol negotiation debugging is on
National#
Dec  3 21:43:38.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Dec  3 21:43:40.095: %LINK-3-UPDOWN: Interface Dialer10, changed state to up
National#
Di10 DDR: outgoing call pending, dialer shutdown delayed
Dec  3 21:44:37.971: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
Dec  3 21:44:39.975: %LINK-5-CHANGED: Interface Dialer10, changed state to standby mode
Di10 DDR: dialer shutdown complete
National#
National#
National#deb ppp auth
PPP authentication debugging is on
National#aa      deb dual
National#deb dual         ial
National#deb dialer
Dial on demand events debugging is on
National#
Dec  3 21:51:07.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Dec  3 21:51:08.199: As5 DDR: rotor dialout [priority]
Dec  3 21:51:08.199: As5 DDR: Dialing cause ip (s=10.0.51.169, d=10.1.110.10)
Dec  3 21:51:08.199: As5 DDR: Attempting to dial 8912360
Dec  3 21:51:08.199: CHAT5: Attempting async line dialer script
Dec  3 21:51:08.199: CHAT5: Dialing using Modem script: backup & System script: none
Dec  3 21:51:08.203: CHAT5: process started
Dec  3 21:51:08.203: CHAT5: Asserting DTR
Dec  3 21:51:08.203: CHAT5: Chat script backup started
Dec  3 21:51:09.183: %LINK-3-UPDOWN: Interface Dialer10, changed state to up
Dec  3 21:51:18.203: CHAT5: Chat script backup finished, status = Connection timed out; remote host not responding
Dec  3 21:51:18.203: As5 DDR: disconnecting call
Dec  3 21:51:18.219: Di10: No free dialer - starting fast idle timer
Dec  3 21:51:18.239: Di10: No free dialer - starting fast idle timer
Dec  3 21:51:18.259: Di10: No free dialer - starting fast idle timer
Is it possible to capture the configuration output from both ends?
Regards.
Here is the relevant config for the headend router:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname RameyGO
boot-start-marker
boot system flash c3825-entservicesk9-mz.124-7.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 5
no logging on
no aaa new-model
resource policy
clock timezone PCTime -6
no network-clock-participate wic 0
no network-clock-participate wic 2
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.251.1
ip dhcp excluded-address 192.168.251.201
ip dhcp excluded-address 192.168.251.202
ip dhcp excluded-address 192.168.251.203
ip dhcp excluded-address 192.168.251.205
ip dhcp excluded-address 192.168.251.206
ip dhcp excluded-address 192.168.251.207
ip dhcp excluded-address 192.168.251.208
ip dhcp excluded-address 192.168.251.210
ip dhcp excluded-address 192.168.251.211
ip dhcp excluded-address 192.168.251.212
ip dhcp excluded-address 192.168.251.213
ip dhcp excluded-address 192.168.251.214
ip dhcp excluded-address 192.168.251.215
ip dhcp excluded-address 192.168.251.216
ip dhcp excluded-address 192.168.251.217
ip dhcp excluded-address 192.168.251.218
ip dhcp excluded-address 192.168.251.219
ip dhcp excluded-address 192.168.251.220
ip dhcp excluded-address 192.168.251.221
ip dhcp excluded-address 192.168.251.222
ip dhcp excluded-address 192.168.251.223
ip dhcp excluded-address 192.168.251.224
ip dhcp excluded-address 192.168.251.225
ip dhcp excluded-address 192.168.251.226
ip dhcp excluded-address 192.168.251.227
ip dhcp excluded-address 192.168.251.228
ip dhcp excluded-address 192.168.251.229
ip dhcp excluded-address 192.168.251.230
ip dhcp excluded-address 192.168.251.231
ip dhcp excluded-address 192.168.251.232
ip dhcp excluded-address 192.168.251.233
ip dhcp excluded-address 192.168.251.234
ip dhcp excluded-address 192.168.251.235
ip dhcp excluded-address 192.168.251.236
ip dhcp excluded-address 192.168.251.237
ip dhcp excluded-address 192.168.251.238
ip dhcp excluded-address 192.168.251.239
ip dhcp excluded-address 192.168.251.240
ip dhcp excluded-address 192.168.251.241
ip dhcp excluded-address 192.168.251.242
ip dhcp excluded-address 192.168.251.243
ip dhcp excluded-address 192.168.251.244
ip dhcp pool 0
   network 192.168.251.0 255.255.255.0
   dns-server 66.119.1.2
   default-router 192.168.251.1
ip flow-cache timeout active 1
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip address-pool dhcp-proxy-client
ip dhcp-server 192.168.251.1
frame-relay switching
voice-card 0
no dspfarm
username pcnet privilege 15 secret 5 $1$lMM.$FcalaNNKI9l5/.sN0z1Qj0
username ramey secret 5 $1$tDLA$WesT2JUPNleDbKveviCbA/
username stores secret 5 $1$ahX2$KkP6M1TJcHviojuRzE6Jl1
username RameyGO secret 5 $1$knF1$xgd6bZtpZL/2zH20muLTj.
username ESunshine secret 5 $1$vzLv$7OR/MM1pDa4PuEzI.CltH.
username WGrand secret 5 $1$DA/Z$E0RwJDONKOW8rzfQuB.FI.
username Republic secret 5 $1$OeJ8$nnoVGoq0Yt9psAYO5HH18/
username Commercial secret 5 $1$/AvL$Mcfpqo90J/bXT4w0AGTml/
username Ozark secret 5 $1$eJgE$0N4.WtMMzl3EESrouMwGD/
username Marshfield secret 5 $1$y.mO$STtcd0z5pEfnJKQN4mDUi/
username Cassville secret 5 $1$ssxi$PWtSdcFaJhq58qg5mLukn1
username Monett secret 5 $1$a4AA$rUZUq7F5BLeoZ1cXr77Sm1
username Division secret 5 $1$F0mg$LeoWBOZCNz.6EkRSRzBJT/
username MHwy secret 5 $1$82Me$9xkfIKHbeycKf6pY6X888.
username MaidenJoplin secret 5 $1$X0Ds$ifZ0psVkwJKEPOAJXYcsd.
username Battlefield secret 5 $1$uJrE$jWwsOzk.opmnAlChFcAwH1
username National secret 5 $1$9/8Z$rvaJgNNw8yjlH6Vn3GT3.1
username WRepublicRd secret 5 $1$tXbY$pe4G//fN4bL7YlDpcYsPK.
username Waynesville secret 5 $1$rrh.$EIK4IVUcK6E1U249ZGLGX/
username MasseyNixa secret 5 $1$q/7P$Fqqp8aBGwTzLmzsAVZRkG/
username WebbCity secret 5 $1$bNg7$SUs55wq9b65h0m9qnw9e51
username Senath secret 5 $1$w7Am$vBc19gS7ivTjS6PMaLkDv/
username NewMadrid secret 5 $1$B1ER$WJ..AvVEtPPklvsObUL3X0
username Owensville secret 5 $1$OV15$Cd8OoQNKLC2nYhoHvsYUR.
username Seymour secret 5 $1$YMJI$uAcnA0r9ZidMYrXQSl1Ei0
username WestPlains secret 5 $1$/r5F$MRvYxJ0dKRnD4iAC2OF/N0
username Aurora secret 5 $1$Zpob$kTkWODAbk5Y2bffw.67DE.
username Purdy secret 5 $1$E5Bw$J0xSaTyrYPpPLTFqA7/Oc.
username Granby secret 5 $1$pdJE$ukwV1QuLqo4Eb9fr4b.9I/
username Lebanon1 secret 5 $1$nkFS$e0YEsDS.N27Dltao2MWVZ0
username Lebanon2 secret 5 $1$JXGT$Q3boiYbmlVCmFjPwDTXMv0
username SCampbell secret 5 $1$/l4B$v1dRKe//xW3Gq4wi2Ae/I1
username SiloamSprings secret 5 $1$T.tg$6oILS7v9E5wNMOtCAAUBz.
username Nevada secret 5 $1$FecW$JJNyGZBB5ml4ZCrV.awko/
username Carthage secret 5 $1$JCjX$bG23OlF/.iSVVx9oezLrq/
username Neosho secret 5 $1$ngs0$4ehAEp1LQkMxwjOtJRnan1
username Ozark2 secret 5 $1$j3/a$bTvBNQrQAxs2.HoNS3hJh1
username College secret 5 $1$91zQ$Ffo0Wm/7oKA1ukMNRjVgC0
username LittlePonca secret 5 $1$O8m8$e8M0IRD3f4LXsKPGuieke1
username PCDFW secret 5 $1$fBqJ$x0SMuNCLjgkgukyRNqt0a.
username rpconline password 7 15201B0F517B252769
username Forsyth secret 5 $1$8EJg$dMuQoQa/l9kuoZittmG.a0
username Telec privilege 15 secret 5 $1$vYUY$9aopCgiaIqUOhLFIBMJBV0
username Downtown secret 5 $1$FLhB$wIx86xKCX00tUrYir5sbg/
username Chestnut secret 5 $1$0fIE$5h8JglQJvGOI2ZwTx6yNx0
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/2/0
framing esf
linecode b8zs
controller T1 0/2/1
framing esf
linecode b8zs
class-map match-any IPT
match access-group 160
policy-map IPT
class IPT
  priority percent 20
  class class-default
  fair-queue
bridge irb
interface Loopback1
ip address 192.168.251.1 255.255.255.0
interface Loopback2
description loopback address for remote sites
ip address 192.168.101.251 255.255.255.0
interface GigabitEthernet0/0
description Connected to LAN
ip address 172.18.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
interface Group-Async1
ip unnumbered Loopback1
no ip unreachables
ip nat inside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer in-band
dialer idle-timeout 1000 either
dialer map ip 192.168.251.221 name Senath broadcast
dialer map ip 192.168.251.222 name NewMadrid broadcast
dialer map ip 192.168.251.223 name Owensville broadcast
dialer map ip 192.168.251.224 name Seymour broadcast
dialer map ip 192.168.251.225 name WestPlains broadcast
dialer map ip 192.168.251.226 name Aurora broadcast
dialer map ip 192.168.251.227 name Purdy broadcast
dialer map ip 192.168.251.228 name Granby broadcast
dialer map ip 192.168.251.229 name Lebanon1 broadcast
dialer map ip 192.168.251.230 name Lebanon2 broadcast
dialer map ip 192.168.251.231 name Nevada broadcast
dialer map ip 192.168.251.232 name Carthage broadcast
dialer map ip 192.168.251.233 name Neosho broadcast
dialer map ip 192.168.251.234 name scampbell broadcast
dialer map ip 192.168.251.235 name Glenstone broadcast
dialer map ip 192.168.251.236 name EBattlefield broadcast
dialer map ip 192.168.251.237 name BattlefieldMO broadcast
dialer map ip 192.168.251.238 name SiloamSprings broadcast
dialer map ip 192.168.251.239 name College broadcast
dialer map ip 192.168.251.240 name LittlePonca broadcast
dialer map ip 192.168.251.241 name PCDFW broadcast
dialer map ip 192.168.251.242 name Forsyth broadcast
dialer map ip 192.168.251.243 name Downtown broadcast
dialer map ip 192.168.251.244 name Chestnut broadcast
dialer map ip 192.168.251.201 name E.Sunshine broadcast
dialer map ip 192.168.251.202 name Division broadcast
dialer map ip 192.168.251.203 name Commercial broadcast
dialer map ip 192.168.251.204 name M_Hwy broadcast
dialer map ip 192.168.251.205 name Republic broadcast
dialer map ip 192.168.251.206 name W.Grand broadcast
dialer map ip 192.168.251.207 name Nixa broadcast
dialer map ip 192.168.251.208 name Monett broadcast
dialer map ip 192.168.251.209 name Ozark broadcast
dialer map ip 192.168.251.210 name Cassville broadcast
dialer map ip 192.168.251.211 name Marshfield broadcast
dialer map ip 192.168.251.212 name MaidenJoplin broadcast
dialer map ip 192.168.251.213 name Battlefield broadcast
dialer map ip 192.168.251.214 name National broadcast
dialer map ip 192.168.251.215 name WRepublicRd broadcast
dialer map ip 192.168.251.216 name Waynesville broadcast
dialer map ip 192.168.251.217 name 32ndJoplin broadcast
dialer map ip 192.168.251.218 name MasseyNixa broadcast
dialer map ip 192.168.251.219 name 402Massey broadcast
dialer map ip 192.168.251.220 name WebbCity broadcast
dialer-group 1
async mode dedicated
peer default ip address dhcp
keepalive 10 3
ppp authentication chap pap
group-range 2/0 2/15
routing dynamic
hold-queue 250 in
router eigrp 1
network 10.10.1.0 0.0.0.255
network 10.10.10.0 0.0.0.255
network 172.17.1.0 0.0.0.255
network 172.18.1.0 0.0.0.255
network 192.168.101.0
no auto-summary
no eigrp log-neighbor-changes
ip route 0.0.0.0 0.0.0.0 172.17.1.1
ip route 10.0.3.0 255.255.255.0 192.168.3.2
ip route 10.0.4.0 255.255.255.0 192.168.4.2
ip route 10.0.5.0 255.255.255.0 192.168.5.2
ip route 10.0.6.0 255.255.255.0 192.168.6.2
ip route 10.0.7.0 255.255.255.0 192.168.7.2
ip route 10.0.8.0 255.255.255.0 192.168.8.2
ip route 10.0.9.0 255.255.255.0 192.168.9.2
ip route 10.0.10.0 255.255.255.0 192.168.10.2
ip route 10.0.11.0 255.255.255.0 192.168.11.2
ip route 10.0.12.0 255.255.255.0 192.168.12.2
ip route 10.0.14.0 255.255.255.0 192.168.14.2
ip route 10.0.15.0 255.255.255.0 192.168.15.2
ip route 10.0.16.0 255.255.255.0 192.168.16.2
ip route 10.0.17.0 255.255.255.0 192.168.17.2
ip route 10.0.18.0 255.255.255.0 192.168.18.2
ip route 10.0.20.0 255.255.255.0 192.168.20.2
ip route 10.0.21.0 255.255.255.0 192.168.21.2
ip route 10.0.23.0 255.255.255.0 192.168.23.2
ip route 10.0.24.0 255.255.255.0 192.168.24.2
ip route 10.0.25.0 255.255.255.0 192.168.25.2
ip route 10.0.26.0 255.255.255.0 192.168.26.2
ip route 10.0.28.0 255.255.255.0 192.168.28.2
ip route 10.0.29.0 255.255.255.0 192.168.29.2
ip route 10.0.30.0 255.255.255.0 192.168.30.2
ip route 10.0.40.0 255.255.255.0 192.168.40.2
ip route 10.0.50.0 255.255.255.0 192.168.50.2
ip route 10.0.51.0 255.255.255.0 192.168.51.2
ip route 10.0.52.0 255.255.255.0 192.168.52.2
ip route 10.0.55.0 255.255.255.0 192.168.55.2
ip route 10.0.56.0 255.255.255.0 192.168.56.2
ip route 10.0.57.0 255.255.255.0 192.168.57.2
ip route 10.0.61.0 255.255.255.0 192.168.61.2
ip route 10.0.62.0 255.255.255.0 192.168.62.2
ip route 10.0.63.0 255.255.255.0 192.168.63.2
ip route 10.0.64.0 255.255.255.0 192.168.64.2
ip route 10.0.65.0 255.255.255.0 192.168.65.2
ip route 10.0.66.0 255.255.255.0 192.168.66.2
ip route 10.0.67.0 255.255.255.0 192.168.67.2
ip route 10.0.68.0 255.255.255.0 192.168.68.2
ip route 10.0.69.0 255.255.255.0 192.168.69.2
ip route 10.0.70.0 255.255.255.0 192.168.70.2
ip route 10.0.71.0 255.255.255.0 192.168.71.2
ip route 10.0.72.0 255.255.255.0 192.168.72.2
ip route 10.0.73.0 255.255.255.0 192.168.73.2
ip route 10.1.110.0 255.255.255.0 172.28.155.99
ip route 10.2.110.0 255.255.255.0 172.18.1.5
ip route 10.10.10.0 255.255.255.0 172.28.155.99
ip route 10.100.51.0 255.255.255.0 192.168.51.2
ip route 10.100.52.0 255.255.255.0 192.168.52.2
ip route 10.100.71.0 255.255.255.0 192.168.71.2
ip route 10.150.40.0 255.255.255.0 172.17.1.1
ip route 10.200.199.0 255.255.255.0 Serial0/0/0:0.6
ip route 63.163.97.0 255.255.255.0 172.17.1.1
ip route 172.16.33.0 255.255.255.0 172.17.1.1
ip route 172.20.112.0 255.255.255.0 172.17.1.1
ip route 172.28.155.0 255.255.255.0 Vlan2
ip route 192.168.1.0 255.255.255.0 Serial0/0/0:0.21
ip route 192.168.1.0 255.255.255.0 192.168.251.221 150
ip route 192.168.2.0 255.255.255.0 Serial0/0/0:0.22
ip route 192.168.2.0 255.255.255.0 192.168.251.222 150
ip route 192.168.3.0 255.255.255.0 Vlan2
ip route 192.168.3.0 255.255.255.0 192.168.251.206 150
ip route 192.168.4.0 255.255.255.0 172.18.1.2
ip route 192.168.4.0 255.255.255.0 192.168.251.217 150
ip route 192.168.5.0 255.255.255.0 172.18.1.2
ip route 192.168.5.0 255.255.255.0 192.168.251.208 150
ip route 192.168.6.0 255.255.255.0 172.18.1.2
ip route 192.168.6.0 255.255.255.0 192.168.251.209 150
ip route 192.168.7.0 255.255.255.0 172.18.1.2
ip route 192.168.7.0 255.255.255.0 192.168.251.224 150
ip route 192.168.8.0 255.255.255.0 Vlan2
ip route 192.168.8.0 255.255.255.0 192.168.251.243 150
ip route 192.168.9.0 255.255.255.0 172.18.1.2
ip route 192.168.9.0 255.255.255.0 192.168.251.225 150
ip route 192.168.10.0 255.255.255.0 172.18.1.2
ip route 192.168.10.0 255.255.255.0 192.168.251.230 150
ip route 192.168.11.0 255.255.255.0 Vlan2
ip route 192.168.11.0 255.255.255.0 172.28.155.11
ip route 192.168.11.0 255.255.255.0 192.168.251.234 150
ip route 192.168.12.0 255.255.255.0 172.28.155.12
ip route 192.168.12.0 255.255.255.0 192.168.251.203 150
ip route 192.168.14.0 255.255.255.0 Serial0/0/0:0.28
ip route 192.168.14.0 255.255.255.0 172.18.1.2
ip route 192.168.14.0 255.255.255.0 192.168.251.228 150
ip route 192.168.15.0 255.255.255.0 172.18.1.2
ip route 192.168.15.0 255.255.255.0 192.168.251.226 150
ip route 192.168.16.0 255.255.255.0 172.18.1.2
ip route 192.168.16.0 255.255.255.0 192.168.251.210 150
ip route 192.168.17.0 255.255.255.0 172.18.1.2
ip route 192.168.17.0 255.255.255.0 192.168.251.205 150
ip route 192.168.18.0 255.255.255.0 Vlan2
ip route 192.168.18.0 255.255.255.0 192.168.251.202 150
ip route 192.168.19.0 255.255.255.0 Serial0/0/0:0.41
ip route 192.168.19.0 255.255.255.0 192.168.251.241 150
ip route 192.168.20.0 255.255.255.0 Vlan2
ip route 192.168.20.0 255.255.255.0 192.168.251.244 150
ip route 192.168.21.0 255.255.255.0 172.18.1.2
ip route 192.168.21.0 255.255.255.0 192.168.251.232 150
ip route 192.168.22.0 255.255.255.0 Serial0/0/0:0.23
ip route 192.168.22.0 255.255.255.0 192.168.251.223 150
ip route 192.168.23.0 255.255.255.0 172.18.1.2
ip route 192.168.23.0 255.255.255.0 192.168.251.220 150
ip route 192.168.24.0 255.255.255.0 172.18.1.2
ip route 192.168.24.0 255.255.255.0 192.168.251.233 150
ip route 192.168.25.0 255.255.255.0 172.18.1.2
ip route 192.168.25.0 255.255.255.0 192.168.251.211 150
ip route 192.168.25.40 255.255.255.255 172.17.1.1
ip route 192.168.25.41 255.255.255.255 172.17.1.1
ip route 192.168.26.0 255.255.255.0 172.18.1.2
ip route 192.168.26.0 255.255.255.0 192.168.251.227 150
ip route 192.168.28.0 255.255.255.0 172.18.1.2
ip route 192.168.28.0 255.255.255.0 192.168.251.231 150
ip route 192.168.29.0 255.255.255.0 172.18.1.2
ip route 192.168.29.0 255.255.255.0 192.168.251.229 150
ip route 192.168.30.0 255.255.255.0 Vlan2
ip route 192.168.30.0 255.255.255.0 192.168.251.201 150
ip route 192.168.31.0 255.255.255.0 Vlan2
ip route 192.168.31.0 255.255.255.0 192.168.251.204 150
ip route 192.168.32.0 255.255.255.0 Serial0/0/0:0.39
ip route 192.168.32.0 255.255.255.0 192.168.251.239 150
ip route 192.168.40.0 255.255.255.0 172.18.1.2
ip route 192.168.40.0 255.255.255.0 192.168.251.238 150
ip route 192.168.50.0 255.255.255.0 Vlan2
ip route 192.168.50.0 255.255.255.0 192.168.251.213 150
ip route 192.168.51.0 255.255.255.0 Vlan2
ip route 192.168.51.0 255.255.255.0 192.168.251.214 150
ip route 192.168.52.0 255.255.255.0 Vlan2
ip route 192.168.52.0 255.255.255.0 192.168.251.215 150
ip route 192.168.55.0 255.255.255.0 172.18.1.2
ip route 192.168.55.0 255.255.255.0 192.168.251.218 150
ip route 192.168.56.0 255.255.255.0 172.18.1.2
ip route 192.168.56.0 255.255.255.0 192.168.251.216 150
ip route 192.168.57.0 255.255.255.0 172.18.1.2
ip route 192.168.57.0 255.255.255.0 192.168.251.212 150
ip route 192.168.58.0 255.255.255.0 Serial0/0/0:0.17
ip route 192.168.58.0 255.255.255.0 192.168.251.217 150
ip route 192.168.60.0 255.255.255.0 Serial0/0/0:0.40
ip route 192.168.60.0 255.255.255.0 192.168.251.240 150
ip route 192.168.61.0 255.255.255.0 172.18.1.2
ip route 192.168.62.0 255.255.255.0 172.18.1.2
ip route 192.168.63.0 255.255.255.0 172.18.1.2
ip route 192.168.64.0 255.255.255.0 172.18.1.2
ip route 192.168.65.0 255.255.255.0 172.18.1.2
ip route 192.168.66.0 255.255.255.0 172.18.1.2
ip route 192.168.67.0 255.255.255.0 172.18.1.2
ip route 192.168.68.0 255.255.255.0 172.18.1.2
ip route 192.168.69.0 255.255.255.0 172.18.1.2
ip route 192.168.70.0 255.255.255.0 172.18.1.2
ip route 192.168.71.0 255.255.255.0 172.18.1.2
ip route 192.168.72.0 255.255.255.0 172.18.1.2
ip route 192.168.73.0 255.255.255.0 172.18.1.2
ip route 192.168.73.0 255.255.255.0 192.168.251.242 150
ip route 192.168.99.0 255.255.255.0 Serial0/0/1:0
ip route 192.168.99.0 255.255.255.0 172.18.1.2
ip route 192.168.105.0 255.255.255.0 192.168.251.208 150
ip route 192.168.106.0 255.255.255.0 192.168.251.209 150
ip route 192.168.109.0 255.255.255.0 192.168.251.225 150
ip route 192.168.111.0 255.255.255.0 Vlan2
ip route 192.168.111.0 255.255.255.0 192.168.251.234 150
ip route 192.168.112.0 255.255.255.0 Vlan2
ip route 192.168.112.0 255.255.255.0 192.168.251.203 150
ip route 192.168.115.0 255.255.255.0 192.168.251.226 150
ip route 192.168.118.0 255.255.255.0 Serial0/0/0:0.35
ip route 192.168.118.0 255.255.255.0 192.168.251.235 150
ip route 192.168.120.0 255.255.255.0 192.168.251.207 150
ip route 192.168.123.0 255.255.255.0 192.168.251.220 150
ip route 192.168.124.0 255.255.255.0 192.168.251.233 150
ip route 192.168.150.0 255.255.255.0 Serial0/0/0:0.36
ip route 192.168.150.0 255.255.255.0 192.168.251.236 150
ip route 192.168.152.0 255.255.255.0 Serial0/0/0:0.37
ip route 192.168.152.0 255.255.255.0 192.168.251.237 150
ip route 192.168.155.0 255.255.255.0 Serial0/0/0:0.19
ip route 192.168.155.0 255.255.255.0 192.168.251.219 150
ip route 192.168.255.1 255.255.255.255 Serial0/0/0:0.21
ip route 192.168.255.2 255.255.255.255 Serial0/0/0:0.22
ip route 192.168.255.7 255.255.255.255 Serial0/0/0:0.24
ip route 192.168.255.9 255.255.255.255 Serial0/0/0:0.25
ip route 192.168.255.10 255.255.255.255 Serial0/0/0:0.30
ip route 192.168.255.14 255.255.255.255 Serial0/0/0:0.28
ip route 192.168.255.15 255.255.255.255 Serial0/0/0:0.26
ip route 192.168.255.21 255.255.255.255 Serial0/0/0:0.32
ip route 192.168.255.22 255.255.255.255 Serial0/0/0:0.23
ip route 192.168.255.23 255.255.255.255 Serial0/0/0:0.20
ip route 192.168.255.24 255.255.255.255 Serial0/0/0:0.33
ip route 192.168.255.26 255.255.255.255 Serial0/0/0:0.27
ip route 192.168.255.28 255.255.255.255 Serial0/0/0:0.31
ip route 192.168.255.29 255.255.255.255 Serial0/0/0:0.29
ip route 198.199.226.250 255.255.255.255 172.18.1.8
ip route 198.200.199.0 255.255.255.0 10.200.199.254
ip route 204.194.125.0 255.255.255.0 172.17.1.1
ip route 206.227.246.195 255.255.255.255 172.17.1.1
ip route 206.227.246.220 255.255.255.255 172.17.1.1
ip route 206.227.246.230 255.255.255.255 172.17.1.1
ip route 208.90.45.128 255.255.255.192 172.18.1.3
ip route 216.174.28.128 255.255.255.192 172.18.1.3
no logging trap
dialer-list 1 protocol ip permit
control-plane
line con 0
login local
transport output telnet
stopbits 1
line aux 0
login local
stopbits 1
line 2/0 2/15
login local
modem InOut
transport input all
line vty 0 4
login local
transport input telnet
line vty 5 15
login local
scheduler allocate 20000 1000
end
Here is the relevant config from the remote router:
hostname National
logging buffered 4096 debugging
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa session-id common
username RameyGO secret 5 $1$hJj8$qSNFoN9sR24RSTVzv7CTK.
username ramey secret 5 $1$0bIu$8UyxcRCXqgMwqLNT2AzOP1
no ip domain-lookup
chat-script backup "" "atdt\T" TIMEOUT 10 CONNECT\C
modemcap entry MY_USR_MODEM:MSC=&F1S0=1
interface FastEthernet0
backup interface Dialer10
ip address 172.28.155.51 255.255.255.0
speed auto
interface Async5
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 20
interface Dialer10
ip address 192.168.251.214 255.255.255.0
encapsulation ppp
dialer pool 20
dialer remote-name RameyGO
dialer idle-timeout 900
dialer string 8912360
dialer-group 1
ppp authentication chap callin
ip classless
ip route 0.0.0.0 0.0.0.0 172.28.155.1
ip route 0.0.0.0 0.0.0.0 192.168.251.1 150
ip route 4.0.0.0 255.255.255.0 192.168.251.1
ip route 204.194.125.0 255.255.255.0 172.28.155.1
ip route 204.194.125.0 255.255.255.0 192.168.251.1 150
no ip http server
radius-server retransmit 3
line con 0
line 2
line aux 0
exec-timeout 0 0
script dialer backup
modem InOut
modem autoconfigure type MY_USR_MODEM
transport input all
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
end
Thank you!
Thanks for the configs, is ti possible to enable below debugs:
- debug modem
- debug confmodem
- debug chat
What model/brand is the modem you have connected to Aux port of National router?
Have you tried removing chat script backup from under line aux 0?
Regards.
Juan
Thank you for the reply. I am using a US Robotics modem(not sure of the model now)....
I will do he debugs Friday morning and post them. I will also remove the chat script then also.
You are wanting to see the above debugs from the National router, correct?
Thank you again!!!
Yes please capture the outputs from the National router. Depending on the model we can try different scripts. Let me know how it goes.
Regards.
Juan,
Ok, getting closer... I removed the chat script backup from line Aux 0 and now I am able to connect to the head-end router but now I do not seem to be authenticating. I have made sure the usernames are created on both routers and I reset the passwords, so I know they are correct on both ends. Can you take a look at the debugs and tell how to resolve this???
Debug ppp auth:
deb ppp auth
National#deb ppp authentication
National#
Dec 10 04:30:48.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Dec 10 04:30:50.235: %LINK-3-UPDOWN: Interface Dialer10, changed state to up
Dec 10 04:31:17.867: %LINK-3-UPDOWN: Interface Async5, changed state to up
Dec 10 04:31:17.867: %DIALER-6-BIND: Interface As5 bound to profile Di10
Dec 10 04:31:17.867: As5 PPP: Treating connection as a callout
Dec 10 04:31:17.867: As5 PPP: Authorization NOT required
Dec 10 04:31:18.047: As5 CHAP: O CHALLENGE id 5 len 29 from "National"
Dec 10 04:31:18.179: As5 CHAP: I CHALLENGE id 52 len 28 from "RameyGO"
Dec 10 04:31:18.179: As5 CHAP: Unable to authenticate for peer
Dec 10 04:31:20.291: As5 PPP: Authorization NOT required
Dec 10 04:31:20.295: %LINK-5-CHANGED: Interface Async5, changed state to reset
Dec 10 04:31:20.295: %DIALER-6-UNBIND: Interface As5 unbound from profile Di10
Dec 10 04:31:25.295: %LINK-3-UPDOWN: Interface Async5, changed state to down
Debug ppp error and neg:
National#deb ppp error
PPP protocol errors debugging is on
National#deb ppp neg
National#
Dec 10 04:55:48.631: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Dec 10 04:55:50.635: %LINK-3-UPDOWN: Interface Dialer10, changed state to up
Dec 10 04:56:18.243: %LINK-3-UPDOWN: Interface Async5, changed state to up
Dec 10 04:56:18.243: %DIALER-6-BIND: Interface As5 bound to profile Di10
Dec 10 04:56:18.243: As5 PPP: Treating connection as a callout
Dec 10 04:56:18.243: As5 PPP: Phase is ESTABLISHING, Active Open
Dec 10 04:56:18.243: As5 PPP: Authorization NOT required
Dec 10 04:56:18.247: As5 LCP: O CONFREQ [Closed] id 21 len 25
Dec 10 04:56:18.247: As5 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Dec 10 04:56:18.247: As5 LCP:    AuthProto CHAP (0x0305C22305)
Dec 10 04:56:18.247: As5 LCP:    MagicNumber 0x2EF829D0 (0x05062EF829D0)
Dec 10 04:56:18.247: As5 LCP:    PFC (0x0702)
Dec 10 04:56:18.247: As5 LCP:    ACFC (0x0802)
Dec 10 04:56:18.419: As5 LCP: I CONFREQ [REQsent] id 117 len 25
Dec 10 04:56:18.419: As5 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Dec 10 04:56:18.419: As5 LCP:    AuthProto CHAP (0x0305C22305)
Dec 10 04:56:18.419: As5 LCP:    MagicNumber 0xCCB4C764 (0x0506CCB4C764)
Dec 10 04:56:18.419: As5 LCP:    PFC (0x0702)
Dec 10 04:56:18.419: As5 LCP:    ACFC (0x0802)
Dec 10 04:56:18.423: As5 LCP: O CONFACK [REQsent] id 117 len 25
Dec 10 04:56:18.423: As5 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Dec 10 04:56:18.423: As5 LCP:    AuthProto CHAP (0x0305C22305)
Dec 10 04:56:18.423: As5 LCP:    MagicNumber 0xCCB4C764 (0x0506CCB4C764)
Dec 10 04:56:18.423: As5 LCP:    PFC (0x0702)
Dec 10 04:56:18.423: As5 LCP:    ACFC (0x0802)
Dec 10 04:56:18.423: As5 LCP: I CONFACK [ACKsent] id 21 len 25
Dec 10 04:56:18.427: As5 LCP:    AuthProto CHAP (0x0305C22305)
Dec 10 04:56:18.427: As5 LCP:    MagicNumber 0x2EF829D0 (0x05062EF829D0)
Dec 10 04:56:18.427: As5 LCP:    PFC (0x0702)
Dec 10 04:56:18.427: As5 LCP:    ACFC (0x0802)
Dec 10 04:56:18.427: As5 LCP: State is Open
Dec 10 04:56:18.427: As5 PPP: Phase is AUTHENTICATING, by both
Dec 10 04:56:18.427: As5 CHAP: O CHALLENGE id 9 len 29 from "National"
Dec 10 04:56:18.559: As5 CHAP: I CHALLENGE id 56 len 28 from "RameyGO"
Dec 10 04:56:18.559: As5 CHAP: Unable to authenticate for peer
Dec 10 04:56:18.559: As5 PPP: Phase is TERMINATING
Dec 10 04:56:18.559: As5 LCP: O TERMREQ [Open] id 22 len 4
Dec 10 04:56:18.675: As5 LCP: I TERMACK [TERMsent] id 22 len 4
Dec 10 04:56:18.675: As5 LCP: State is Closed
Dec 10 04:56:18.679: As5 PPP: Phase is DOWN
Dec 10 04:56:18.679: As5 PPP: Phase is ESTABLISHING, Passive Open
Dec 10 04:56:18.679: As5 LCP: State is Listen
Dec 10 04:56:20.675: As5 LCP: TIMEout: State Listen
Dec 10 04:56:20.675: As5 PPP: Authorization NOT required
Dec 10 04:56:20.675: As5 LCP: O CONFREQ [Listen] id 23 len 25
Dec 10 04:56:20.675: As5 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Dec 10 04:56:20.675: As5 LCP:    AuthProto CHAP (0x0305C22305)
Dec 10 04:56:20.675: As5 LCP:    MagicNumber 0x2EF83351 (0x05062EF83351)
Dec 10 04:56:20.675: As5 LCP:    PFC (0x0702)
Dec 10 04:56:20.675: As5 LCP:    ACFC (0x0802)
Dec 10 04:56:20.679: %LINK-5-CHANGED: Interface Async5, changed state to reset
Dec 10 04:56:20.679: %DIALER-6-UNBIND: Interface As5 unbound from profile Di10
Dec 10 04:56:20.679: As5 LCP: State is Closed
Dec 10 04:56:20.679: As5 PPP: Phase is DOWN
Dec 10 04:56:25.679: %LINK-3-UPDOWN: Interface Async5, changed state to down
There is a problem with  authentication for sure, National device sends out a TERMREQ once it receives credentials from remote RameyGO router. Have you verified credentials, passwords at both ends must be the same.
You can also try to disable AAA from National router (it is configured to use local authentication but it would be worth to try without it).
If you would like to use different user/pass combination then you can make use of the "ppp chap hostname " and "ppp chap password commands under Dialer/Group-Async interfaces:
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080094333.shtml
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a00800b4131.shtml
