User does not provide any authentication data
dianewalker
We have ASA 5510 and the Radius server.  We were able to login to Cisco VPN client last week.  For some reason, we got this error message in Cisco VPN client log:  "User does not provide any authentication data".  The authentication never went through.  We were not able to login to Cisco VPN client.  Do you have any suggestions how to fix this problem?
Thanks.
Diane
mvsheik123
Level 7
Level 7
Check the ASA--> Radius connectivity and see if the authentication test is successful from ASA to Radius.
thx
MS
Thanks for your prompt response, MS.
The authentication test ran successfully from ASA to Radius.  Do you have any other suggestions?
Diane.
If nothing has changed from server  (ASA & RADIUS) end, make sure client is not corrupted (unless the issue is with multiple client pcs). Try re installing the vpn client. Also, I found some the below article (may not be related to your issue, but worth reading). Check it out.
http://support.microsoft.com/kb/975488
Thx
MS
