ip address dhcp command not available on C3550
Answered Question
Nov 20th, 2011
I'm trying to configure my C3550 with fast ethernet port 0/48 assigned to vlan 2 in static access mode and SVI vlan 2 configured as dhcp client.
But I see command ip address dhcp is not available on interface vlan 2:
Cat3550(config-if)#ip ad
Cat3550(config-if)#ip address ?
  A.B.C.D  IP address
Could it be a problem related to the version running on the equipment (see below the output of sh version command not sure of what
EA1 stands for)?
I read here http://www.cisco.com/en/US/docs/ios/12_3t/ip_addr/command/reference/ip1_i1gt.html#wp1164194
that this command was introduced in version 12.1(2)T
If it is a version problem is there any possibility to download upgraded version for free?
Thanks!
Antonio
Cat3550>sh ve
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(20)EA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 04-Feb-04 23:28 by yenanh
Image text-base: 0x00003000, data-base: 0x00827298
ROM: Bootstrap program is C3550 boot loader
Cat3550 uptime is 4 hours, 47 minutes
System image file is "flash:c3550-i5q3l2-mz.121-20.ea1.EMI.bin"
cisco WS-C3550-48 (PowerPC) processor (revision C0) with 65526K/8192K bytes of memory.
Processor board ID CAT0622Z0FC
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:09:E8:28:F5:00
Motherboard assembly number: 73-5701-06
Power supply part number: 34-0967-01
Motherboard serial number: CAT06210B05
Power supply serial number: LIT061601HR
Model revision number: C0
Motherboard revision number: B0
Model number: WS-C3550-48-SMI
System serial number: CAT0622Z0FC
Configuration register is 0x10F
Correct Answer by mahesh18 about 2 years 5 months ago
Hi giuseppe,
Here is sh ver
3550SMIA#sh ver
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 20:28 by gereddy
Image text-base: 0x00003000, data-base: 0x012A99FC
3550SMIA uptime is 2 days, 16 hours, 46 minutes
System restarted at 16:30:05 MST Thu Nov 17 2011
System image file is "flash:c3550-ipservicesk9-mz.122-44.SE6.bin" *****************************************
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes of memory.
Processor board ID CAT0722R1DQ
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0D:28:BC:FD:80
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT072101VJ
Power supply serial number: DTH07220Y3N
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0722R1DQ
MAhesh
Average Rating: 5 (2 ratings)
Giuseppe Larosa Sun, 11/20/2011 - 07:50
Hello Antonio,
generally speaking yes the IOS version really counts for the feature supported.
in your case C3550 is now an old platform that might be upgraded up to 12.2(44)SE as we can see
http://www.cisco.com/en/US/products/hw/switches/ps646/prod_command_reference_list.html
the dhcp option is not present even in last command reference see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_44_se/command/reference/cli1.html#wpmkr1861935
to upgrade you need a regular contract
So it looks like it is not supported on C3550
Hope to help
Giuseppe
mahesh18 Sun, 11/20/2011 - 07:51
Hi Antonio,
ip address dhcp is interface config command as shown below
3550SMIA(config)#int fa0/17
3550SMIA(config-if)#ip add
3550SMIA(config-if)#ip address d?
dhcp
3550SMIA(config-if)#ip address dhcp ?
  client-id  Specify client-id to use
  hostname   Specify value for hostname option
Its not available under global config.
Mahehs
Giuseppe Larosa Sun, 11/20/2011 - 08:06
Hello Mahesh,
what version is running on your C3550?
I tried to look in the command reference but I didn't see the option.
it may help Antonio the original poster.
Best Regards
Giuseppe
Correct Answer
mahesh18 Sun, 11/20/2011 - 08:17
Hi giuseppe,
Here is sh ver
3550SMIA#sh ver
export@cisco.com.
MAhesh
alabarba82 Sun, 11/20/2011 - 14:43
Thank you guys!
so it really seems I could solve the issue by upgrading my IOS version to Version 12.2(44)SE6.
Anyway it's really strange, as me too I have just verified, this command to not be inserted in the command reference.
Beside this I have purchased this switch on ebay and I have regular invoice, Giuseppe when you say "I should have a regular contract", do you mean a sort of payment technical support contract?
Reza Sharifi Sun, 11/20/2011 - 16:26
Antonio,
Cisco does not offer warranty and contract services for equipment purchased on ebay or any other auction site.  In addition to service contract, you need a CCO account to download the IOS.
alabarba82 Wed, 11/23/2011 - 14:35
Hi Reza,
excuse me but I never had a chance to deal with Cisco software before now, so I'm pretty ignorant about this.
I logged with my cisco credentials that I received when I obtained CCNA certification and I tried to visit http://www.cisco.com/cisco/software/navigator.html section, I followed all the steps and I finally was able to download the image
Release:12.2.44-SE6
Filename: c3550-ipbasek9-mz.122-44.SE6.bin , Feature set: IP BASE
for Cisco Catalyst 3550 48 SMI Switch
I didn't proceed with the download as I'm not sure if I can download it as I was asked to agree on the following points:
1.         That you shall be bound by Cisco's End User Software License Agreement  posted at the above URL regarding your use of any Cisco software you download from this web site;
2.         That you are only entitled to download Cisco software for the Cisco  hardware chassis or device or the particular application software or  signature file for which you have paid the applicable software license  fees;
3.         That you must purchase a Cisco Operating system Software feature set  upgrade license if the feature set you intend to download is not  included in your initial license;
4.         That you have a current and valid service contract that covers either           the specific Cisco hardware chassis or device for which you are  downloading software and/or the software image or subscription file update (e.g., For Intrusion Detection System) that you are  downloading;
5.         That Cisco reserves the right to: (a) charge you for, and you agree to pay for, software /signature file downloads to which you are not  entitled, and (b) immediately suspend or terminate your access to this web site if you Download software to which you are not so entitled.
I initially agreed with the points above only to see if I was allowed to download the image then I verified i was allowed and didn't proceed with the download.
Now I'm pretty confused about how getting updates and software download works.
Can you please help me to understand better how this process works?
Thanks!
Antonio
Login or Register to take actions
Posted November 20, 2011 at 7:31 AM
Stats:
Replies:7 Avg. Rating:5
Views:1627 Votes:0
Shares:0
Categories: Switches
Related Content
Discussions Leaderboard
Rank Username Points
1 15,007
2 8,150
3 7,730
4 7,083
5 6,742
155
77
70
69
50
