cucm cube OmniPCX4400 call forward issue
Nov 20th, 2011
Hi all
I have a setup like this,
             h323       h323
CUCM7.5 --- CUBE ----OmniPCX4400
Cube is acting as H323 gateway and PSTN gateway.
The problem is the call from OmniPCX to CUCM7.5 which is set to CFA to PSTN number drops after one ring.
(All other stuff works fine, such as call transfer).
Below is the related configuration.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
  no h225 timeout keepalive
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class codec 10
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g722-64
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 11 pots
description Outgoing PRA (Dial 1)
destination-pattern 1T
progress_ind alert enable 8
clid network-number 3490001
port 0/0/1:15
dial-peer voice 20 voip
description Inbound to CUCMBE
destination-pattern 3[012]..
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.100.10
dtmf-relay h245-alphanumeric
no fax-relay sg3-to-g3
no vad
dial-peer voice 9999 voip
tone ringback alert-no-PI
description Accept all Inbound VoiP Calls
voice-class codec 1
voice-class h323 1
incoming called-number .
clid network-number 9998
no vad
dial-peer voice 6000 voip
description Alcatel OmniPCX 4400
destination-pattern [678]...
voice-class codec 10
voice-class h323 1
session target ipv4:192.168.1.15
session transport udp
no vad
Arun Thomas Wed, 11/23/2011 - 13:07
Can you please post the PRI-interface configs. Are you able to dial from OmniPCX to PSTN via H323 GW?
seungkijung Wed, 11/23/2011 - 13:53
Good question. OmniPCX has its own PRI trunk to PSTN. The H323 gateway is used between internal phones(from OmniPCX phones to CUCM phones) and to provide PSTN connection to CUCM phones.
The design is not so fancy(this was implemented long time ago, i don't know when...), but I'd like to know if the call forward is possible in this design.
controller E1 0/0/1
pri-group timeslots 1-31
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn map address .* plan national type unknown
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
One more thing, when the call was forwarded to PSTN and dropped, the q931 shows normal call clearing.
acampbell Wed, 11/23/2011 - 16:03
  • Green, 3000 points or more
Can you try adding this to the config:-
voice service voip
supplementary-service h450.12
Try retesting
Alex
seungkijung Wed, 11/23/2011 - 16:48
Thanks for your input.
But that didn't make any difference.
Arun Thomas Wed, 11/23/2011 - 21:26
From the isdn debugs, do you see the router forwarding all the digits to telco? Please post the q931 debugs as well.
seungkijung Thu, 11/24/2011 - 13:30
The q931 debug.
Bearer  Capability i = 0x8090A3
                         Standard = CCITT
                         Transfer Capability = Speech
                         Transfer Mode = Circuit
                         Transfer Rate = 64 kbit/s
             Channel ID i = 0xA98386
                         Exclusive, Channel 6
             Calling Party Number i = 0x0883, '3490001'
                         Plan:National, Type:Unknown
             Called Party Number i = 0x88, '0212601207'
Nov 22  14:33:53.042: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x9C5E
Nov 22  14:33:58.830: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0x9C5E
             Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov 22  14:34:06.966: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x1C5E
             Cause i = 0x8090 - Normal call clearing
Nov 22  14:34:07.190: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref =  0x9C5E
Nov 22  14:34:07.194: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref =  0x1C5E
