How to trigger failover in a multi context ASA firewall environment?
Answered Question
Nov 22nd, 2011
What is the most common way to configure failover triggers on two ASA running in multiple context mode?
It seems that there is any easy approach in which the standby takes over only if it loses connection with the primary on the configured "failover lan interface".
What kind of other options are there?  What about configuring failover if either the trunking uplink (to WAN) or trunking downlink (to LAN) interfaces on the primary go down?
Correct Answer by mirober2 about 5 years 2 months ago
Hi Greg,
You just need to enable interface monitoring for your sub-interfaces in the context where they are allocated. The ASA will then failover if the e0/0 link goes down or if the devices can't send/receive interface monitoring packets on any of the enabled subinterfaces. For example:
firewall001# changeto context MAIN
firewall001/MAIN# conf t
firewall001/MAIN(config)# monitor-interface inside
http://www.cisco.com/en/US/docs/security/asa/asa84/command/reference/m.html#wp2123112
-Mike
Overall Rating: 5 (1 ratings)
aimarchitect Tue, 11/22/2011 - 13:55
Mike,
Thanks for the info.
Say I want to configure the standby to take over if the either the e0/0 trunk uplink to the WAN or the e0/1 trunk downlink to the LAN get disconnected (accidentally unplugged) on the primary...
I would confugrure that in the system context, right?  If so, what would I add to the current primary system configuration to make that happen?
ASA Version 8.2(2)
hostname firewall001
interface Ethernet0/0
description Uplink to WAN
interface Ethernet0/0.14
description DMZ
vlan 14
interface Ethernet0/0.104
description Outside-104
vlan 104
interface Ethernet0/0.200
description Outside-200
vlan 200
interface Ethernet0/1
description Downlink to LAN
interface Ethernet0/1.23
description MGMT-23
vlan 23
interface Ethernet0/1.24
description  MGMT-24
vlan 24
interface Ethernet0/1.500
description Client1-Inside
vlan 500
interface Ethernet0/2
shutdown
interface Ethernet0/3
description LAN/STATE Failover Interface
interface Management0/0
shutdown
failover
failover lan unit primary
failover lan interface ASA-Failover Ethernet0/3
failover link ASA-Failover Ethernet0/3
failover interface ip ASA-Failover 10.0.1.1 255.255.255.252 standby 10.0.1.2
no asdm history enable
arp timeout 14400
console timeout 0
admin-context MAIN
context MAIN
  allocate-interface Ethernet0/0.14
  allocate-interface Ethernet0/0.200
  allocate-interface Ethernet0/1.23-Ethernet0/1.24
  allocate-interface Management0/0
  config-url disk0:/MAIN.cfg
context CLIENT1
  allocate-interface Ethernet0/0.104
  allocate-interface Ethernet0/1.500
  config-url disk0:/CLIENT1.cfg
prompt hostname context
Correct Answer
mirober2 Wed, 11/23/2011 - 05:01
Hi Greg,
-Mike
aimarchitect Wed, 11/23/2011 - 14:15
Thanks Mike,
I see now that monitoring is configured within the context.  Failover from primary to standby in one context doesn't affect another context, right?
mirober2 Thu, 11/24/2011 - 04:58
Hi Greg,
It depends if you are using Active/Standby failover or Active/Active failover. With Active/Standby, all contexts are Active on the same unit at the same time and a failover event affects the entire unit. With Active/Active, you can assign your contexts to failover groups and a failover event may only affect one group and not the other. With Active/Active, one group is Active on one unit and the other group is Active on the second unit.
-Mike
Related Content
