SA5020 Mac Printing
jasbryan Wed, 11/23/2011 - 08:25
  • Silver, 250 points or more
Clay,
I would first start with latest version of OS for SA500 devices. After verifying you running on code 2.1.71 and testing to see if you’re still having same problem. Then it’s time to start further trouble shooting. First you want to make sure printer has connectivity to your network. Can other computers print to printer? Can you ping the printer? If you’re computer is wirelessly connected do you have wireless isolation turn on? Checking firmware settings? Under diagnostic you can actually run a packet capture on the vlan to see the flow of packets to and from SA500 device. After checking settings and still having problems (printing) then give us a call @ 1-866-606-1866 and open a support case.
Always read release notes prior to upgrading version of OS
Jasbryan
clayjackson Wed, 11/23/2011 - 20:44
Ok - I do have the latest firmware on both the SA 520 and the printer; and I cans print when direct connected via USB.
Tomorrow I'll try a wired network connection and also a WinTel PC.
Will keep you posted - my suspicion is that the SA520 is not happy with Bonjour
Sent from my iPhone
Clay Jackson
Related Content
