Warning message
How to add DN in Device Profile
Answered Question
We have a user profile setup with Barge configured, which has a number of Directory Numbers configured on the expansion model.  Normally these are setup as BLF SD's on phone configured without Barge, but I need to change one of the DN's configured on the Barge profile (screenshot CCM.jpg).
I can easily see how to remove one of the DN's:
Modify Button Items -> select relevant Associated Item (screenshot CCM2.jpg) -> move to Dissociate These Items and Save.
But if I click one of the Line [X] - Add a new DN, it takes me to a screen to create a new DN rather than use an existing DN!
Thanks in advance for your help!
Correct Answer by Rob Huffman about 5 years 8 months ago
Hi Chris,
I do think that this is actually what you want to see. Can you try
click on Line [X] - Add a new DN and when it takes you to the screen to create a new DN
add the shared/existing DN and > save. Then go back to the UDP and check.
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 11/23/2011 - 09:48
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chris,
I can't test this right now for you, but usually anywhere in CUCM
where you see Add a new DN you can add "any" DN not just a new/unused DN. This would mean
a Shared line existing DN like you need in this instance.
Cheers!
Rob
Hi Rob,
This is what I thought - it 'should' be simple, but if I click on Line [X] - Add a new DN it takes me to the screen to create a new DN, rather than just adding one to the profile.
If I select Modify Buttons, it takes me to the screenshot I attached in my initial post, but I cannot see how I link a specific DN to the profile.
Chris
Correct Answer
Rob Huffman Wed, 11/23/2011 - 10:19
  • Hall of Fame,
    Founding Member
Hi Chris,
Cheers!
Rob
Hi Rob,
You got it!  Having not configured a line like this before, I was entering the DN number I wanted to add but the rest of the fields don't populate under I enter the DN number, selected the Route Partition, then moved to the next field.
What threw me was I tested adding my DN number and clicking Save without populating the Route Partition field, and CUCM added a second entry for my DN number.
Anyway, problem solved, and thanks very much for your help.
Chris
Rob Huffman Thu, 11/24/2011 - 06:56
  • Hall of Fame,
    Founding Member
Hey Chris,
Nice work my friend
I'm sorry for the rather lame explanation, but at least you got it figured out.
Cheers!
Rob
Related Content
