more_jazZz_2 Wed, 11/23/2011 - 09:38
Do you know tool like "Power calculator" http://tools.cisco.com/cpc/ it usefull for configuring specs. You can choose your platform and depending on amount of power consuption it give you different variants.
Best regards,
Zak.
Patrick McHenry Wed, 11/23/2011 - 09:47
We occasional lose a switch and it's usually because of the power supply. As far as access layer switches are concerned, I was wondering if there is a different model for say PoE compared to a switch that is not PoE. Or 48 port vs. 24 port. Or, 370 vs. 3560.
Thanks, Pat.
Reza Sharifi Wed, 11/23/2011 - 15:03
  • Cisco Designated VIP,
    2017 LAN
For smaller 1RU fixed switches, there isn't much of choice of power supplies, you can add more power for POE vs non-POE switches, but that is all you can do. It is not like the modular switches with many choices of PSUs.
If you lose PSU occasionaly in spesific location, I would have an electrician check the power sources and test for power fluctuation for a period of time.
Patrick McHenry Fri, 11/25/2011 - 07:18
Reza,
so,the same PS that works in a PoE, switch WS-C3560-24PS-S will  work for a WS-C3560-48TS-S? And will if also work in a WS-C3750-48TS-S?
I would like to order just one back-up power supply if possible to cover all models in the event one goes bad
Thanks, Pat.
