11-23-2011 12:51 PM - edited 07-03-2021 09:07 PM
Hi all
I have doing EAP-Sim authentication with WLC 5508, client mobile is samsung galaxy 2, Radius proxy (Car).
So, i get message from WLC (Debug) which show the message like mobile do not going authentication state. That will make the mobile do not authentication, so, i have attach file or log also. Then, if anyone know or any idea, please help me
Thanks alot
Please see my log in attach file
11-24-2011 04:27 AM
Your mobile phone is not responding to the EAP identity requests sent by the WLC so it looks like a misconfig on the phone.
Moreover, it seems that you configure your eap identity request timeout to be something like 2 minutes ? That's best reduced to something like 10 seconds or so.
11-24-2011 07:59 AM
Hi Nicolas
Thanks with your support, so, i may say that it is the first time to do EAP-SIM authentication but i may not sure that i have correct to do configuration also on mobile and wlc. Then, do you have any idea or recommend to share to me ?
Because right now, I do not know what is the problem and how to solve it at all.
11-24-2011 11:07 AM
The WLC acts as a authenticator and it doesn't care which EAP type you use. The WLC is a "pass through"
What radius server are you using ? Have you tested this with a client different from your tablet ?
11-24-2011 05:41 PM
Well, what about client or mobile device ? which Eap-authentication to using? or it doesn't care also eap type also, correct?
We using Car Radius proxy.
Well, i will going to try with nokia.
Note: I may need some resarch or any document how to implement it such as WLC and mobile device
anyone have or can share, please help T_T
