Warning message
some weird SSL VPN commands
Nov 24th, 2011
hello,
to customise my SSL  VPN portal these are the commands I typed, I took them form one of the cisco user guide configuration, but unfortunately, the router  does not recongnise those commands. I don't know what's wrong.
-    customise the SSL VPN Portal
(config)# webvpn context SecContext
(config-webvpn-context)# login-message “please enter your credentials”
(config-webvpn-context)# title “SecContext SSL VPN Service”
(config-webvpn-context)# secondary-color darkseagreen
(config-webvpn-context)# title-color #808080
(config-webvpn-context)# text-color white
(config-webvpn-context)# secondary-text-color black
config-webvpn-context)# exit
I  also typed the commands that follows. but when I authenticate  successfully, nothing appears that is I don't have any output. please do  some one help me.
-    access servers configuration
(config-webvpn-context)# url-list ListForClientlessUsers
(config-webvpn-url)# url-text “IntranetServer” url-value serverurl
(config-webvpn-url)# heading “ClientlessAccess”
(config)#ip name-server dnsserveraddress
-    outlook server configuration
(config-webvpn-context)# url-list WebOutlook
(config-webvpn-context)# url-text “OutlookWebAccess” url-value serverurl
(config-webvpn-context)# heading “OutlookWebAccess"
-    map the URL list above to the policy group
(config-webvpn-context)# policy group SecDefaultPolicy
(config-webvpn-policy)# url-list WebOutlook
(config-webvpn-policy)# url-list ListForClientlessUsers
(config-webvpn-policy)# hide-url-bar
I am using a cisco 20811 router IOS version 12.4(13r)T
thanks.
Diego Armando C... Thu, 11/24/2011 - 06:36
  • Bronze, 100 points or more
Please post the whole config.
show run | sec webvpn
Is the default-group configured?
priscille Thu, 11/24/2011 - 07:01
the default group is the same as the group configured.
priscille Thu, 11/24/2011 - 08:27
the show run | sec webvpn command did show any result. this is part of the result of th show run command
webvpn gateway RingoGW
ip address x.x.x.x port x.x
http-redirect port x
ssl trustpoint TP-self-signed-2814278058
inservice
title "testsite"
secondary-color #C0C0C0
title-color #808080
ssl authenticate verify all
url-list "ListForClientlessUsers"
   heading ".ClientlessAccess."
   url-text ".IntranetServer." url-value " "
login-message "testsite"
   timeout idle 100
   timeout session 36000
default-group-policy SecDefaultPolicy
aaa authentication list sslvpn
gateway RingoGW domain domain.com
max-users 2
inservice
end
thank you.
priscille Thu, 11/24/2011 - 08:58
infatct, I that output is for clientless mode of the ssl vpn.
But please tell me appart from Anyconnect, do you know any other ssl client, compatible with all operating systems, I can configure for my vpn?
because Anyconnect package is not install on my router.
