FWSM Failover configuration - One Context
Nov 24th, 2011
Is it possible to configure only one context in H.A. in FWSM? , yesterday  I tried to configure this but I can´t .
Please check my configuration and tell me your opinon, or not is possible ,  maybe I have to configure all context in H.A.
This message appears in the console when I active the FAILOVER
Nov 23 2011 19:20:04: %FWSM-1-105002: (Secondary) Enabling failover.
Nov 23 2011 19:20:08: %FWSM-1-105038: (Secondary) Interface count mismatch
Nov 23 2011 19:20:08: %FWSM-1-104002: (Secondary) Switching to STNDBY - Other unit has different set of vlans configured
Nov 23 2011 19:20:11: %FWSM-1-105001: (Secondary) Disabling failover.
Nov 23 2011 19:23:58: %FWSM-6-302010: 0 in use, 46069 most used
FWSM-Primario# show failover
Failover On
Failover unit PrimaryFailover LAN Interface: FAILLINK Vlan 1100 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 50%
Monitored Interfaces 1 of 250 maximum
failover replication http
Config sync: active
Version: Ours 4.1(5), Mate 4.1(5)
Last Failover at: 19:18:35 UTC Nov 23 2011
        This host: Primary - Active
                Active time: 1125 (sec)
                admin Interface inside (10.1.1.1): Normal (Not-Monitored)
                admin Interface outside (20.1.1.1): No Link (Not-Monitored)
                FW-GoB-Fija Interface WASOB2N-SISOB2N-Fija (10.115.30.36): Normal (Waiting)
                GESTION-WAS Interface OUTSIDE (10.116.20.22): Normal (Not-Monitored)
                GESTION-WAS Interface U2000 (10.123.20.1): Normal (Not-Monitored)
        Other host: Secondary - Cold Standby
                Active time: 0 (sec)
                admin Interface inside (0.0.0.0): Unknown (Not-Monitored)
                admin Interface outside (0.0.0.0): Unknown (Not-Monitored)
                FW-GoB-Fija Interface WASOB2N-SISOB2N-Fija (10.115.30.37): Unknown (Waiting)
                GESTION-WAS Interface OUTSIDE (0.0.0.0): Unknown (Not-Monitored)
                GESTION-WAS Interface U2000 (0.0.0.0): Unknown (Not-Monitored)
Stateful Failover Logical Update Statistics
        Link : STATELINK Vlan 1101 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         0          0          0          0
        sys cmd         0          0          0          0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        0          0          0          0
        UDP conn        0          0          0          0
        ARP tbl         0          0          0          0
        Xlate_Timeout   0          0          0          0
        AAA tbl         0          0          0          0
        DACL            0          0          0          0
        Acl optimization        0          0          0          0
        OSPF Area SeqNo         0          0          0          0
        Mamba stats msg         0          0          0          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       0       0
        Xmit Q:         0       0       0
FWSM-Primario#
FWSM-Primario#
The configuration in the SW-6500
SW-PRIMARY#sh run | in fire
firewall multiple-vlan-interfaces
firewall module 3 vlan-group 1,2
firewall vlan-group 1  10,20,25,400,1709
firewall vlan-group 2  1100,1101,1111,1112
SW-SECUNDARY#sh run | in fire
firewall vlan-group 1  900,1709
ip subnet-zero
FWSM-Primario(config)# sh run
: Saved
FWSM Version 4.1(5) <system>
resource acl-partition 12
hostname FWSM-Primario
hostname secondary FWSM-Secundario
domain-name cisco.com
enable password 8Ry2YjIyt7RRXU24 encrypted
interface Vlan10
interface Vlan29
shutdown
interface Vlan400
interface Vlan1100
description LAN Failover Interface
interface Vlan1101
description STATE Failover Interface
interface Vlan1111
description FWSW_7200_GoB_Fija
interface Vlan1112
description FWSW_7200_GoB_BA
interface Vlan1709
passwd 2KFQnbNIdI.2KYOU encrypted
class default
  limit-resource IPSec 5
  limit-resource Mac-addresses 65535
  limit-resource ASDM 5
  limit-resource SSH 5
  limit-resource Telnet 5
  limit-resource All 0
ftp mode passive
pager lines 24
failover
failover lan unit primary
failover lan interface FAILLINK Vlan1100
failover link STATELINK Vlan1101
failover interface ip FAILLINK 10.115.30.17 255.255.255.252 standby 10.115.30.18
failover interface ip STATELINK 10.115.30.21 255.255.255.252 standby 10.115.30.22
failover group 1
  preempt
  replication http
no asdm history enable
arp timeout 14400
console timeout 0
admin-context admin
context admin
  allocate-interface Vlan10
  allocate-interface Vlan29
  config-url disk:/admin.cfg
context GESTION-WAS
  allocate-interface Vlan1709
  allocate-interface Vlan400
  config-url disk:/GESTION-WAS
context FW-GoB-Fija
  allocate-interface Vlan1111
  allocate-interface Vlan1112
  config-url disk:/FW-GoB-Fija.cfg
  join-failover-group 1
prompt hostname context
Cryptochecksum:8b5fabc676745cfbafd6569c623a98b1
: end
SECUNDARY FIREWALL.
FWSM# sh run
: Saved
hostname FWSM
enable password S13FcA2URRiGrTIN encrypted
interface Vlan100
shutdown
interface Vlan900
interface Vlan1100
interface Vlan1101
interface Vlan1111
interface Vlan1112
interface Vlan1709
class default
ftp mode passive
pager lines 24
no failover
failover lan unit secondary
failover group 1
  preempt
  replication http
arp timeout 14400
console timeout 0
admin-context PCBA-NAT
context PCBA-NAT
  allocate-interface Vlan900
  config-url disk:/PCBA-NAT
context FW-GoB-Fija
Cryptochecksum:c7529707b6d10d02c296a57253a925b2
: end
FWSM#
I WILL APRECIATE YOUR COMMENTS, BECAUSE IT´S IMPORTANT , THE FWSM SUPPORT FOR DEFAULT 3 CONTEXT.
Robert Soto.
mirober2 Sat, 11/26/2011 - 05:12
  • Cisco Employee,
Hi Robert,
Unfortunately no, this is not possible.
Since you enable failover at the system level, all contexts will particpate in failover and there is no way to change this.
Additionally, both firewalls in the failover pair must have identical licenses, VLANs, and software versions in order for failover to work properly.
-Mike
