Enable SSH V2
Answered Question
Nov 23rd, 2011
Hi, i have a switch 2960 24TC-L with c2960-lanbasek9-mz.150-1.SE.bin and SSH v1 enabled.
When i try to enable SSH v2 the swith tell me that i have to create a crypto key rsa. I generated the crypto key rsa with 1024 bits and when i try to enable the SSH v2 i receive the same message.
Correct Answer by Peter Paluch about 5 years 5 months ago
Damian,
The current SSH session should not break during the recommended operation. However, for maximum resiliency, I would personally suggest using a different CLI access method (Console or Telnet) just to make sure the SSH session does not get corrupted. In any case, if the SSH session was closed before the SSH keys are generated anew, you would not be able to SSH into the device anymore.
Best regards,
Peter
Overall Rating: 4.8 (6 ratings)
Peter Paluch Wed, 11/23/2011 - 15:53
  • Cisco Employee,
Hi Damian,
Can you please post the exact message the switch tells you when trying to enable the SSHv2? Just in case, SSH v1.99 means - strangely enough - that the switch is running both SSHv1 and SSHv2.
Best regards,
Peter
Latchum Naidu Thu, 11/24/2011 - 05:02
  • Blue, 1500 points or more
Hi Damian,
Follow the below procedure in order to get enabled ssh v2 on your router.
Firstly is ssh enabled?
router#sh ip ssh
SSH Disabled - version 2.0
%Please create RSA keys to enable SSH.
Authentication timeout: 60 secs; Authentication retries: 5
In this case its not, if you got a error saying that sh ip ssh is not
recognized then you would know that ssh is not supported or possibly
that the command is different for your platform.
How to enable SSH on a Cisco 800 series
router# config term
router(config)#crypto key generate rsa usage-keys label router-key
The name for the keys will be: router-key
Choose the size of the key modulus in the range of 360 to 2048 for your
Signature Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]: 1024
Encryption Keys. Choosing a key modulus greater than 512 may take
a few minutes.
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
router (config)#
000047: *Mar 1 20:40:50.843 UTC: %SSH-5-ENABLED: SSH 1.99 has been enabled
router (config)#exit
According to the line above SSH has been enabled, we can confirm this
by running the sh ip ssh command again.
router#sh ip ssh
SSH Enabled - version 1.99
Authentication timeout: 120 secs; Authentication retries: 3
router#
Now setting the router up to accept ssh logins
Usually it will anyway because by default the transport is set to all
transport preferred all
transport input all
But we want to change that
Router#conf t
line vty 0 4
access-class 1 in
exec-timeout 30 0
privilege level 15
login local
transport preferred ssh
transport input ssh
Write your config and test it.
Please rate the helpfull posts.
Naidu.
Latchum Naidu Thu, 11/24/2011 - 05:32
So what is the issue you are facing?
Naidu.
Peter Paluch Thu, 11/24/2011 - 06:55
  • Cisco Employee,
Damian,
I apologize for not checking the screenshots you have attached. Hmm, this is an interesting issue. Perhaps you have several RSA keypairs configured, and the SSH is using some short keypair that does not allow running SSHv2.
I suggest erasing all existing RSA keypairs using the crypto key zeroize rsa as follows:
configure terminal
% All RSA keys will be removed.
% All router certs issued using these keys will also be removed.
Do you really want to remove these keys? [yes/no]: yes
Then try generating a new RSA keypair anew:
configure terminal
crypto key generate rsa label ssh modulus 1024
The name for the keys will be: ssh
% The key modulus size is 1024 bits
[OK] (elapsed time was 3 seconds)
This alone should make sure that the SSH is able to run in SSHv2. In addition, I have given the keypair a special name that can be used to select it in diverse applications. We can make sure that SSH is using this particular RSA keypair using these commmands:
configure terminal
ip ssh rsa keypair-name ssh
Then you should be able to run SSHv2. Can you verify that? Thanks!
Best regards,
Peter
Correct Answer
Peter Paluch Thu, 11/24/2011 - 07:33
  • Cisco Employee,
Damian,
Best regards,
Peter
darp27609679 Thu, 11/24/2011 - 08:01
Thanks! I remove the old rsa key and i can upgrade to ssh v2.
GARY HAHN Tue, 05/12/2015 - 13:44
Just one note here that with similar model and version, I had to log out of SSH and telnet in before I could successfully complete all steps (even though there was no warning about problems in trying to complete them while doing so).  It appeared that the zeroize didn't actually work while SSH v 1 session was active.
